Old Iron
Hot Rolled
- Jan 15, 2008
- Andalusia, Alabama
All I seen have a 3 jaw chuck on them, Is there a reason a 4 jaw isn't used?
Paul
Paul
I have a Kearney & Trecker dividing head with a 3-jaw chuck. I recently purchased a South Bend Heavy 10 that didn't have a 3-jaw chuck, so I took the chuck off the dividing head, and made an adapter to use it on my Heavy 10.
I was disappointed with the performance of the chuck; not in the accuracy, it repeated within .002. It took too many turns of the chuck wrench to adjust this chuck for different size workpieces, due to the slow-speed scroll which increases the gripping force of the chuck. And the chuck was horribly out of balance for any spindle speed other than a back gear speed.
I came to the realization that this chuck should be left on the dividing head, as it was definitely matched for it; both in capacity and in accuracy. That is where it is going to spend the rest of it's (or my) life.
I will purchase a new 8" 3-jaw chuck with 2-piece jaws for my lathe. A 4-jaw chuck would be too difficult to dial in, because I do not think that this dividing head has a free wheeling spindle. I suppose that someone will prove me wrong on this. I do not care.
Lord Byron
Side note on L-W dividing heads - if it is not a universal one (that can be geared into the table) how do you disengage the worm to get it to freewheel?
Paul
The worm bearing is pressed in an eccentric collar. On the close edge of the main barrel, there are a pair of screws, one on each side of where the shaft goes in, that push against the eccentric collar in little pockets to revolve it a little for take-up, left or right. Remove the left screw and revolve the dividing plate right to disengage the worm from the worm gear.Hey - I've got the same L-W dividing head.
Side note on L-W dividing heads - if it is not a universal one (that can be geared into the table) how do you disengage the worm to get it to freewheel? I did not see a way, but I may be missing something obvious as I've used it once so far, but need to make a gear soon.
Paul
Not to rain on anybodys parade - Dividing heads are obsolete, unless you need 27 or 127 divisions. I've got 2 of them & a rotary table. A quick/super spacer will do 99% of your indexing, plus horz. & vert. clamping plus a thru hole. And of coarse my spacer has an adaptor plate for the tailstock off an Atlas lathe. The tailstock is good for centers, pipe centers, spider centers, & if I'm not happy with that, I can use the adaptor plate with the steady rest for end work.
Notice
