Howdy, Folks.
My name is Craig Holden, and I live in Austin, Texas where I teach middle school history in LTISD and repair pedal steel guitars on the side. I've been working on steels for quite a while now, and I have run into this problem before, but I'm still not sure what the issue is.
I'm (trying) to thread 5/32 steel rod using an 8-32 die (hand-held). The rod I'm cutting is hard stuff (not sure what the composition is, though). I'm going easy and using cutting oil, but for some reason when I try to thread a nut on to the rod I've just cut, the nut threads on loosely and will easily slip off. It's almost as if the rod stock has somehow shrunk. Also, the 1-1/2" threaded end looks warped and wavy. I suspect a crappy die (new, Harbor Freight), as the first rod I cut came out OK, but the second one I tried to cut is now garbage. The cutting oil I'm using is some kind of foamy stuff in a spray can.
Any advice on this would be much appreciated, including a brand recommendation on a good die.
Thanks much!
Craig
Thanks much!
Craig
