Not trying to ! Just looking for some input from people in the know about how slow I can turn this motor-fan assy. without frying it.
Ive tried looking it up - cant find it. Not trying to reinvent the wheel, just looking for info. Thats it.
Looking up thermistor cut-out temp values commonly stocked as repair parts, plus use of a temp probe or sensing "gun", a few man-days worth of screwing about, and you can FIND a number.
But "why"?
The "examples" for what must be considered when a motor
(AC OR DC) must be run really slow already appear all around us.
- one is high "pole" count ceiling fans. Low power for their size, they can dissipate heat well, too.
- another is "gearmotors". Can't run the motor slow enough, gear it down, right in the same housing.
- and then there are motors that may have to sit at or near "stall" for long hours to hold tension for some process as if they were an infinite spring or such, then ramp-up to high speed to move the load.
Here we find "blower duty" motors, with a second motor running fast perched atop them and forcing serious amounts of cooling air through the primary motor.
Trying to get the performance or benefits of
any of those common and long, long, proven solutions from an ORDINARY motor and marginal controller is the part I called "pointless".
Most especially on an extractor, filter, collector, "mover" of dust or such where the dynamics of the "fluid" flow are not linear, either.
One of the more useful approaches, BTW, can be found on the "variable power" residential vacuum cleaners (ours are Samsung).
A slide control right in the handgrip adjusts motor speed // vacuum strength so it can do a "heavy" pickup task - or be turned-down to where it won't try to ingest and choke on thin curtains.
No matter what brand is on those, you can bet that there was a bit of engineering and testing invested in getting them to do the do and...... last a while, too!
You can embark on some fractional exercise at reinventing some subset of all that wheel, "alone, and in the dark", as they say.
Cheaper to respect what that motor & control maker shipped as best they dared do without creating a warranty-coverage monster... then seek some other combo more appropriate to your needs
as-built if that isn't a good enough match. No shortage of choices. You aren't the first entity with a need.
