jackal
Titanium
- May 4, 2006
- northwest ARK
I ran into something lately that is strange. After years of power tapping in a lathe, all of a sudden my tapped holes are stripped.
I use a tap handle or a crescent wrench against the carriage and put a live center in the end of the tap. Slow (65 rpm) and it looks good, plus the tap is tight coming out. These rods that are giving me problems are 1" to 2" diameter x 2 ft long. Could it be that the end that is up inside the spindle is moving and toggling around? These are chrome cylinder rods and I have sandpaper between them and the chuck jaws to prevent scratching. Maybe, the back end is flopping around. They aren't spinning or slipping in the sandpaper, I have that marked.
When you take the tap out and look the hole is tapered from the start of it and the threads are tapered. In about 1" deep the threads look ok. I measured after drilling and the hole is onsize.
I will figure this out and reply,
But, has anyone else had this happen before?
Let me know,
JAckal
Let me know,
JAckal
