O/T - Creating a CAD file from a simple template?
Page 1 of 2 12 LastLast
Results 1 to 20 of 36
    Oct 2005
    CANADA
    Ontario
    646
    73
    190
    Default O/T - Creating a CAD file from a simple template?
    I need a 2D CAD file for a simple 1/4" thick poly-carbonate template, aprox. 36" x 2".
    Google shows me many different ways this can be done, there's scanning, tracing, photo digitizing etc. Any way to do this w/o fancy equipment? If I do bring it somewhere what's the simplest, most accurate method? Costs?
    Oct 2010
    Dewees Texas
    1,680
    22
    411
    I take it you do have a CAD program and can use it? With my old dinosaur CAD 2D for DOS I can print actual size and get a very accurate drawing. I sometimes print what I have drawn and compare to an actual part I am duplicating, then adjust as necessary. Not into that fancy scanning and digitizing, so I can not help there.
    If you have a sample you are trying to duplicate, I think I would tape some masking tape to it and crank off pencil marks in the milling machine and measure at those points then transfer measurements to the CAD program.
  3. Likes digger doug liked this post
    Oct 2005
    erie,pa
    8,373
    15230
    4079
    Would like to see what exactly the template looks like, complexity
    wise.
    What kind of accuracy are you looking for ?
  5. Likes Wild West liked this post
  6. #4
    Oct 2014
    Maine
    548
    7
    272
    Here's my experience after doing a fair number of 2D profiles.
    If it's a simple shape, take measurements and model it from your measurements.
    If it's a complex shaped flat part, use a scanner. Unlike a photo, this won't have parallax error. You then import the photo into CAD and you can draw your splines on top of it. Take a few key measurements so you can check your scale.
  7. Likes Wild West liked this post
  8. #5
    Oct 2005
    CANADA
    Ontario
    646
    73
    190
    Quote Originally Posted by FredC View Post
    I have Autocad 2013, I want to take this profile and do some virtual wind tunnel testing with it.
    wise.
    Pretty simple, I don't need the holes, just the outline. Doesn't need to have extreme accuracy.
  9. #6
    Jul 2004
    Houston, TX USA
    27,079
    Measure part
    Assign stations to assist with above
    In Autocad, place points, draw splines, save as whatever, like dxf
    All it amounts to is some "Y" dimensions and their locations in "X"
  10. Likes Bobw liked this post
  11. #7
    Jan 2007
    Ontario, Canada
    478
    192
    438
    I do stuff like this on a scanner. You will have to make dot's or reference marks so you can connect all the profiles in cad. They can be crosshairs, small punch marks, or pieces of scotch tape with pinholes in them. You need enough so that for every scan you have at least 3 in view. Bring all the pictures into cad (I use Rhino) and then line them all up and draw your profile. I also put a 6" scale on the scanner bed to double check the scaling is right.
    For larger stuff that doesn't fit on the scanner bed such as a transmission, motorcycle case, etc I use graph paper, tape, and a good sharp knife. Just cut a bunch of pieces that fit all the way around the flange and over lap a good 2-3 inches each sheet. trim the outer profile to fit, mark any holes, then before you remove the paper poke small holes in the overlapped sections so that when you scan in all the sheets you can digitally line them all back up again. It sounds hokey, but it's really easy, and accurate if you put the time in.
  12. #8
    Oct 2014
    Maine
    548
    7
    272
    Quote Originally Posted by Terry Keeley View Post
    From the picture, it looks symmetric. If that the case, this is very easy. As John said, mark off stations at known distances from the nose. Use calipers to measure the width at each station. Plug it into AutoCAD.
    If it's not symmetric, I'd still do stations. First I'd measure width at each station as above. Next I'd stand the template on edge on a flat surface and measure depth from the top of the template down to the table. That gives you everything you need to model it.
  13. #9
    Oct 2005
    CANADA
    Ontario
    646
    73
    190
    Thanks for the help. From what I'm hearing I can do this myself by either measuring the part at different stations from the nose (height gauge and calipers?) or scanning it and converting to CAD with s/w.
    It's not quite symmetrical, but only the first 12" or so from the nose is curved. From there back it's straight top and bottom, I know the radius of the nose. When I bring it into CAD does it "blend" the points to make a smooth curve? Obviously the more points the better.
    As you can tell I have very limited CAD experience, I did a 2D drawing once to cut some foam to protect electronics parts but that was all radii and straight lines...
  14. #10
    Sep 2010
    Vancouver Canada
    632
    406
    197
    Best would be to lay down the points from measurement and use a spine to go through as many points as possible. Then it will be smooth. It would be helpful to establish a tolerance in your mind for how close to each point you want to get. With lots of points you could use straight lines and fillets where they meet, but that may not be as accurate as splines.
  15. #11
    Apr 2008
    Helmer, Indiana, USA
    1,150
    233
    443
    You can use an indicator mounted in the spindle of the mill to get a better "X" increment to go along with the "Z" increment the dial indicator provides.
    With the coordinates it wouldn't take much to get you a model if you want to send the numbers to me.
  16. #12
    Oct 2005
    CANADA
    Ontario
    646
    73
    190
    Quote Originally Posted by rcoope View Post
    Thanks, will try that once I get the points.
    Quote Originally Posted by Kyle Smith View Post
    Thanks for the offer, I have some local help to draw it once I get the points.
    That's also what my toolmaker buddy suggested (actually we both came to the same conclusion). Clamp the template on the mill table and use an edge finder to get points every .100" or so from the nose...
  17. #13
    Aug 2005
    CT
    7,486
    236
    1507
    Actually, that part is much easier than that method.
    Put the part into the vise with edge-up, pick up the tip of the radius for X0, then put a dial indicator in the spindle with a sharp tip, zero it on the straight edge
    then move the table by say .100 increments ( or less if you need better accuracy ) and read the dial for each increment.
    When done, take the table you've created and put a point at each of the coordinates in Autocad.
    Then use the Spline command and connect the dots.
    To make it easy, in the Autosnap settings select NODE so all you need to do is click the points in the proper order.
  18. Likes digger doug, henrya liked this post
  19. #14
    Mar 2008
    vacaville ca
    289
    19
    61
    don't think r13 will do raster. But Draftsight free is an autocad clone. install it and attach the image then just trace it and scale to some known points.
    What I did here for a friend. Found a jpg of the logo and mopar and traced it.
  20. #15
    Oct 2005
    CANADA
    Ontario
    646
    73
    190
    Quote Originally Posted by SeymourDumore View Post
    That's an even better idea!
  21. #16
    Dec 2012
    Se Ma USA
    1,240
    94
    696
    Autocad r4-5. Take a pic with a high res camera from as far back as you can. Stay perpend to the part. Put 2 scales in the pic on the same plane as the part, one in x, other one in Y. Import raster image into autocad and scale image to match scales in pic. Trace with splines and done.
  22. #17
    Mar 2017
    CHINA
    1,968
    906
    To some extent, you guys are giving bad advice. If his goal is a smooth curve, the fewest points will give the smoothest curve. If the goal is to accurately reproduce something he has, then the largest number of points will be the most accurate but not the smoothest. There's a whole technique to the curve-smoothing thing, and Autocad is not the top end of that software group.
    If he's trying to do both, Alias Design Studio is maybe the most approachable with Class A surfaces, smooth accurate curves, etc etc - Autodesk bought them, like a black hole swallows light - I think they have a thirty-day free evaluation program. But you'd have to learn how to use it, which is sort of non-trivial.
  23. #18
    Oct 2005
    erie,pa
    8,373
    15230
    4079
    Quote Originally Posted by SeaMoss View Post
    I think it would be cheaper to have it Cordaxed, than buy a new CAD sytem.
    We still don't know the accuracy required. It looks like an airfoil,
    and some have some pretty tight requirements.
  24. #19
    Oct 2005
    CANADA
    Ontario
    646
    73
    190
    Quote Originally Posted by Scruffy887 View Post
    Will give that a shot, sounds like a fairly simple solution, thanks.
    It's a side profile for one of my R/C boats. I'm going to make a diffuser at the back of the hull to help keep the prop planted, I want to try different shapes/angles in Autocad CFD.
    Not proficient enough to quote accuracy requirements, as long as it's "close" that'll do.
  25. #20
    Nov 2009
    Massachusetts
    120
    30
    If it's an airfoil, it will be described by a relatively simple equation that generates all the surface location points. It will not be described only as a point cloud.
