O/T - Creating a CAD file from a simple template? - Page 2
Page 2 of 2 FirstFirst 12
Results 21 to 36 of 36
  1. #21
    Oct 2005
    9,549
    16654
    4875
    Quote Originally Posted by Joe Gwinn View Post
    If it's an airfoil, it will be described by a relatively simple equation that generates all the surface location points. It will not be described only as a point cloud.
    Uhm no, not yet it won't.
    It appears the template is from something "developed in the field" and now needs
    now needs measured, to make a part, or "derive that equation".
  2. Likes Terry Keeley liked this post
  3. #22
    Mar 2017
    CHINA
    1,813
    1125
    Never did this but always wanted to : APT can do that directly. And APT is in the public domain, it's free
    The only bad part is, he'd have to know the equation that determined his arc ...
  4. #23
    Sep 2010
    Vancouver Canada
    654
    427
    205
    If you measure a bunch of points manually and put them in Excel you can probably do a decent polynomial fit to get an analytic expression for most of the curve. It was thinking after my last post that doing it that way would be nice because if you wanted to redesign and optimize it you'd want to start with equation driven curves.
    OP if you attach a file with measurements every .1" or so we can all monkey with it. Gotta do something in the run up to New Years!
  5. #24
    Sep 2010
    Vancouver Canada
    654
    427
    205
    Nb I just went away and made an NACA2215 airfoil using an online calculator. I exported 100 points and made a Curve Through XYZ points in Solidworks which works perfectly once you futz around with the file in Word and Excel to get the proper space delimited text file with the columns mapped to the correct XYZ axes. I still think here you want a polynomial approximation but the curve thing here works well.
  6. #25
    Oct 2005
    CANADA
    Ontario
    702
    90
    202
    OK, I've entered a bunch of individual points for the top side, I realize now I should have used the line command and drawn a line from point to point.
    Been Googling for an hour, any way to join the points into a smooth line?
  7. #26
    Oct 2010
    Dewees Texas
    1,789
    23
    438
    Do have a draw option in the menu? In my old dinosaur CAD (Design CAD 2D for DOS) which I still use I would select DRAW then CURVE and then connect the dots.
    If you can not find another way with your CAD, I could do it in mine then convert to DXF for you.
  8. #27
    Oct 2005
    CANADA
    Ontario
    702
    90
    202
    Thanks for the reply. When I select any of the Draw commands (line, polyline, circle, arc) it's looking for an x-y coordinate, it won't let me select my existing points...
  9. #28
    Aug 2005
    CT
    7,532
    248
    1539
    Quote Originally Posted by Terry Keeley View Post
    Type in "OSNAP", and youll'be presented with a window for Object Snap settings.
    Check the "Object Snap On" box, check the "Node" box and uncheck all others.
    Now you can just type "SPLINE" and then click away at each point, the cursor will "snap" to points and points only, but make sure to do it in the proper order otherwise you will have to start over.
    Oh, If I were you I would put the points on one layer ( say Layer0 ) and the spline on a different one, that way if you do screw up it will be much easier to delete
    the spline or add other points.
  10. #29
    Oct 2005
    CANADA
    Ontario
    702
    90
    202
    Quote Originally Posted by SeymourDumore View Post
    You're awsome, I've been looking for that for hours, thought I needed the Spline function but couldn't figure the Nodes part.
    I owe you a beer!
  11. #30
    Oct 2005
    CANADA
    Ontario
    702
    90
    202
    I got the side profile drawn thanks to some help from Seymore but I screwed up and didn't rotate the UCS before starting. Now if I extrude it along the Z axis it gets "tall" instead of "wide". If I did it right the drawing would have been on the "wall" instead of the "floor".
    I think I need to use UCSFOLLOW = 1 but I can't get the drawing to rotate about the x axis.
    Any ideas?
  12. Likes digger doug liked this post
  13. #31
    Nov 2009
    Massachusetts
    133
    30
    Lofting used to be done with a full-size drawing on an aluminum sheet painted white. This traditional approach collapsed under the pressures of WW2, leading to the mathematical approach.
    See "Aircraft Analytic Geometry: Applied to Engineering, Lofting, and Tooling", J. J. Apalategui (Author),‎ L. J. Adams (Author); McGraw-Hill 1944, 285 pages. See chapters 10 and 11 for the math.
    Aircraft Analytic Geometry: Applied to Engineering, Lofting, and Tooling: J. J. Apalategui, L. J. Adams: 978112411453: Amazon.com: Books
  14. #32
    Oct 2005
    9,549
    16654
    4875
    No need to school me.
  15. #33
    Aug 2005
    CT
    7,532
    248
    1539
    Terry
    I am still not clear on what you intend to do, but if all is needed that the initial point pattern is on a different plane, just select
    the appropriate view ( left, right, top etc ), select the entire solid ( window select if not a block ) then click "Rotate", pick the point about which
    you want the rotation and type in 90 deg.
    But again, not knowing exactly what you need, if your spline is of the correct shape and size, then all you need is to extrude to the length.
    If it's let's say a 1/8" sheet, just type "extrude", select the closed profile and type in .125 for the extruded length.....
  16. #34
    Oct 2005
    CANADA
    Ontario
    702
    90
    202
    Terry
    Again, thanks for the help.
    The rotate command seems to rotate the object about the Z axis, I need to rotate it about X.
    In the SW Isometric view on the right in post #30, I want to make what's now the top the front and the front the bottom (as shown by the square at the top right).
  17. #35
    Aug 2005
    CT
    7,532
    248
    1539
    Terry
    Then go to the left or right view and select the objects to rotate.
    Yes, ACAD is dumb and it will show you X/Y as the axis on the UCS, but in the real space you will be rotating about the X.
  18. #36
    Oct 2005
    CANADA
    Ontario
    702
    90
    202
    Got it, thanks for the help!
