crusty1007
- Apr 25, 2010
- Horseshoe Bend
Feedback & knowledge request.
Block 225 Buick v6 "oddfire"
Oil galley diameter from pickup tube mating face to timing cover/oil pump .440"
Depth 6.25" on horizontal, 2" on vertical - Integral 90 degree blind intersection .
Wanting to enlarge oil galley to .625" or close (casting wall thickness is suspect)
Here is what I am understanding from reading threads on drilling cast iron.
Use a "Core drill"
Cut dry
Low speed
High feed
Now, the questions
How large should I increase the drill bit size each pass, 1/32, 1/16 +/- or just go after it, taking into consideration desired finished hole size for reamer?
Is the Core drill the proper bit to control wander or blow out? - Is there a better drill bit or operation for this that will follow current bore path?
Can I get away with doing this with a hand drill or do I need to bolt it down to a drill press or mill?
TIA
Thean
Use a "Core drill"
Cut dry
Low speed
High feed
Now, the questions
TIA
Thean
