Been suspicious of my inability to breath thru my nose easily for a couple of years now. Nasal passages on the right side felt closed up, which in turns causes me to mostly breathe thru my mouth, which isn't good. I think it affects my sleep quality, too. Actually, most of the time I can inhale, but not exhale thru my right nostril. Left one not so bad. It is like a check valve....air in, but not out. It is solid blockage and no amount of internal pressure would let so much as a wisp of air out. None. Very discomforting. When I get a cold, it's horrible having a runny nose and not being able to blow it!!!
So, after much thought I finally made a doctor appointment with a E/N/T specialist. He sprays some sort of anesthetic (?) in my nostrils, let it soak in, then proceeds to snake some long slender inspection scope up into my skull!
A few "Aha"s and "hmmms" as he rattled off a string of ten dollar words to his assistant, who was attempting to keep up with his dictation on their laptop. I thought to myself that I couldn't have kept up with those words at that speed, either. He stopped and asked her if she got all that, and to her credit she said no and he then repeated it at a slower speed. At least I know my chart is accurate with the diagnosis.
He puts the scope down, turns to me and says "you are going to be spending some time with me, but you be sleeping thru most of it!" My bung hole puckers up hearing that!
Anyhow, deviated septum...blah blah blah.....and some sort of polyps. I told him I had done some research and had come to the conclusion that I thought it was polyps, too. Then I asked him how big they are, to which he made a circle with thumb and forefinger about the size of an quarter!!!
I was taken aback that they were so big, and can't remember if he said if there was more than one. Got an appointment for a cat scan of my skull so he can see the sinus cavity where these things are growing at.
I spoke to a close friend today who just happened to have had this same procedure done on his snout about a year ago. He said they fixed the deviated septum and removed 4 polyps on him.
Said the total cost was $30,000!!!!!
I replied "Holy Crap" and thought he was shitting me, but he said it was 15 grand per side. Was outpatient surgery. He had his done up in Kansas City at some hospital up there. Stayed overnight at a motel across from the hospital.
Said he had quite a bit of congestion after the surgery and he got kinda scared and was having trouble breathing, so they went and visit the ER for some attention to be sure it wasn't anything serious.... they said it's common and to just calm down and breathe thru his mouth and drink some fluids- which loosened things up and soothed his nerves and calmed him down. THey didn't have to do anything to him, and he went home the next morning and has been fine ever since.
Says he's never slept so good as he does now, food tastes better and he breathes lots easier. Has to spray some sort of "Flonase"- a corticosteroid- in the sinuses for some reason- like to keep them from reoccuring again. I hope that has no side effects
