moonlight machine
- Nov 19, 2007
- marysville ohio
I made a big mistake 3 years ago. I bought SWIMBO a Frigidaire "Gallery" stove. It is the usual 4 burner with the oven underneath the cook top. It uses natural gas. It is on its 3rd gas valve for the oven. It seems to stick, after you turn on the oven more often than not you need to remove the drawer and lay on the floor so you can tap on the gas valve. 1 or 3 good raps and the oven lights up and holds the temp you select. so now the gas valve is screwed up again. At 76.00 each this is getting old. Ideas anyone?????
