Lemme now when you get it to be able to suck that messy s**t OUT.. chopped fibreglass and 40+ year worth of seasonal rearrangement into mouse nest and turd, specifically - so I can place crossed layers of proper roll fibreglass.
....and here we go...off to the races.
IIRC their are studies showing cellulose superior
to fiberglass (loose fill) and much better than
batt.
They were even showing how cellulose applied on top
of batt will help with the air sealing that batt
insulation fails at. Plus, anything spray applied will fill
in irregular spaces much faster and better than batts.
As far as animal infestation, any insulation will harbor
mice/rats/chipmunks/squirrels/bats etc.
I re-did the parents house (built in 1900) by vacuuming
all the insulation out, it was full of junk.
Vermiculite was the insulation of choice in this house.
After I vacuumed it all out (long hose to tank outside)
I then went in with a shop vac, and a bristle brush
attachment, and got out all the "black" that old houses
have.
Took (2) full cleanings, backbreaking work down on my stomach, but it was worth it.
Afterwards, I replace it with loose fill cellulose.
I would have liked to try a light misting of water on top
to form a "crust" to keep it from moving around,
seen it done with a fancy nozzle attachment into the hose.
However, I think an ordinary pump sprayer would be just fine.
I would like to try loose fill Styrofoam sometime,
would need a PVA misted on top to keep it in place.
FWIW Fiberglass is very similar to asbestos as far
as the lung damage problems, and I hear that the
rules might be clamping down on it in the near future.
