SLG
Cast Iron
- Jun 4, 2014
- New Mexico
I ordered a master rebuild kit for a diesel engine and it arrived with a set of Mahle pistons with piston rings already installed. This seems absurd to me, as there is no way to measure ring end gap without removing the rings from the pistons. I'm assuming Mahle installed the rings, but I haven't found out for sure - yet.
If you were building an engine, would you trust Mahle to have ground the rings to the proper end gap or would you remove them and measure? (I think I know your answer)
Are piston rings apt to be damaged by installing/removing/re-installing? IOW - should I demand a replacement set of rings?
