I am cleaning up an older large mill vise by made by Van Norman. One of the oil Zerks is meant to feed the (probably) bronze bushing that supports the handle end of the steel screw that tightens the vise jaws. Upon dis assembly I see there is no hole at all in the bronze bushing that would allow oil put into the Zerk to reach the steel shaft of the screw. Even if this was originally porous bronze it now seems burnished and thus sealed off.
Should I add a hole to the bushing or any reason why not?
Thank you,
Regards,
GeoD
Thank you,
Regards,
GeoD
