shapeaholic
Stainless
- Oct 14, 2003
- Kemptville Ontario, Canada
While working on the rebuild of My hendey T&G lathe and have come across a vexing question.
Here's the situation,
In the feed/belt selector box there is a shaft that runs the belt part of the drive, that is running in Oilite bushings. This shaft runs at speeds up to 2500 rpm, and is, like the rest of the machine grease lubricated. Everything else on the lathe is either running in bronze or ball bearings, depending on the speed. This is the only "high" speed use of bronze.
The shaft that runs in these bushings has worn pretty badly and will be replaced. I have spoken to several other hendey owners and this is a "known" problem area.
The use of oilite is shown in a penciled in note on a drawing, date unknown.
My experience with oilite is that it is usually oiled, either by a drip cup or by an oil gun at regular intervals.
I was wondering is I might be better off using oil to lube this??
any comments?
thanks
Pete
any comments?
thanks
Pete
