geardoc
Cast Iron
- Aug 8, 2012
I've got a sticky situation. Guy has three Japanese made mini-crawlers that he imported in the 80's and uses in his orchard.
They are pretty similar to a small Satoh chassis, but some company in Japan made the tracks, rollers, idlers, sprockets, frames, and the brake conversion components.
Think of little mini dozer or mini agricultural crawler about the size of an 15hp diesel garden tractor(like a Yanmar or Kubota garden tractor, not lawn mower based, an actual little baby tractor).
One of them he was able to source a new engine for from a Japanese parts company. The engine is a specially made variant of the Mitsubishi KE70 2 cylinder diesel. When they are new, they have about 450 lb/in cranking pressure, and they use glow plugs. I'm basing that off the one that has the new engine in it with only 4 hours on it.
His other two have suffered head gasket failures. Magnaflux and pretty careful checking, and obvious damage to the head gaskets themselves(and they are the original probably 35-40 year head gaskets)- lead me to believe a head gasket replacement will fix the two that are broken down.
The problem is that these engines were ordered to spec(kinda like how Thermo King used to order their own versions of the Isuzu C201 diesel for reefers) and there are enough oddball differences in the head and block that a regular KE70 head gasket won't work because of coolant port alignments.
The company that did these crawlers went under in the very late 70's. Mitsubishi was kind enough to check and they haven't had stock on the head gasket for this engine variant going back to when they bought Satoh outright.
The best of the failed head gaskets looks like it would make an acceptable template for me to make one.
The engines will have probably 450 lb/in cranking pressure, like the others- I've re-ringed them, and surfaced the heads. Glow plugs will be used- I have warned him that ether is not to be used, ether is a hanging offense for me. I have warned him that if he uses f#cking ether on any engine I've built for him from now on, I will not hesitate to void the warranty.
I do not have any CNC equipment but I have made a couple copper head gaskets for Brit and Jap Scrap motorcycles on my manual equipment.
In your opinions, if I used my manual machines and copper sheet a few mills thicker than the stock gasket(which is a stamped steel gasket with rubbery dressing), would a gasket made from copper and dressed with something like Cometic's gasket dressing material hold up to diesel cranking pressures ? I do plan on annealing it, as well before dressing.
And I'm not just asking to have my hand held here. I've been reading my metallurgy texts, I've read the previous discussions on copper and head gasket making that have occurred, but most of the people who have actually done it, are like me and it has been on air cooled engines, which is a different animal.
I know on the copper gaskets that were used on Race Hemi applications, Cotton Owens and Harvey Standridge always told me they weeped and leaked a little unless you used the proper dressing and kept your heads torqued properly, so I'm also concerned about that in this diesel application as diesel + glow plugs + H2O do not mix. Well, they mix, but then you are thoroughly up shit creek.
I do not want to try it with steel shim stock, as I've never had any luck making them last what I consider an acceptable life. The Mopar small block guys begged me to make them a steel shim head gasket for the SB's, and the material gradually failed in season or two racing when they didn't change them.
I appreciate any and all advice. I will say this- he's not going to let me retrofit another engine, he's not going to let me order a set of gaskets custom order from Taiwan- he owns an orchard and he's just too cheap.
So if it would be possible to keep the opinions and knowledge shared focused on whether or not a head gasket can be shop made for a high compression 2 cylinder diesel(and it's really not that high a compression for a diesel). Will it hold up ? If I am meticulous and careful, can I accomplish this with my manual machines ? Is copper the appropriate material ? What material would you use ?
I am not someone who rigs up stuff or tries to half ass work. I am going to be very honest here: this winter has been very rough here in the mountains, business has sucked, and I am doing whatever work I can with my job shop to get by. So if it was a better economy, I'd probably refuse to do something like this, instead of just getting a professional head gasket fabricator in Taiwan or Korea to make a run of of 5 or 10 of these gaskets for him to put up. But honestly, I can't turn away the work. I am ashamed to admit that, but right now, every penny counts. No has been bringing their hobby projects much, ag equipment isn't used much during winter so it doesn't break much so I'm not seeing business there, it's too cold to ride motorcycles so I'm not seeing that business, and I'm not seeing much racing or auto business.
So honestly, your help and advice is appreciated, as it is helping me do some very shitty jobs that keeping the lights on, and keeping bologna on hand sandwiches in my sizeable gut. I realize that questions like this are probably offensive and a waste to most of the production machinists here, so I apologize to those individuals for whom this is drivel.
To any and all of you- thank you for taking your time to read, and comment. I cannot thank you enough.
