MwTech Inc
Titanium
- Feb 6, 2005
- Fishersville VA
Ok I can't do it anymore, back is hurting as I write.
2 years ago bought a new 6" 12 ga National box/pan brake, manual operation.
My back will no longer take the pressure pulling up on the levers.
No problem to place two hydraulic cylinders to push, already have a self contained pump unit.
Doing research I found flow dividers, standard units. The info says you cannot sync two cylinders precisely. Over a 10" stroke just how far will they be off?
I can't see much difference with two people pulling on two levers being in sync either.
The cylinders will need to be fully retracted after every "push" anyway to re position the sheet metal, so they will always be starting from an absolute zero.
Suggestions otherwise, are there other controls usuable without going to encoders etc?
