I think that only someone with access to that table or a manual would be able to answer for certain. I suspect OMT could fit a variety of optical scales - that is what they were good at.
My toolmakers microscope has a mixture of units, depending on what seems most natural. For example, the rotating table vernier is degrees and minutes. Some at least of the optical measurements are dms. Other optical scales measure things like radiuses where the units are in inches. The micrometer drums can be inches or metric. The slip gauge set made for it is inches.
As others have said, you need to get familiar with what the scales are telling you, making sure you are counting in the right direction etc. You also need to use a calculator (well I do anyway). It isn't like a modern DRO, but what you are looking is very precise and at that price a bargain if it isn't abused and you need what it does.
I would not be put off by having dms scales if that actually is the case. Just buy a cheap childrens school scientific calculator. This will do the conversions for you at the push of a button. You can do it manually on paper of course, but why work that hard.
It could be that you are concerned about setting up compound angles correctly. If so, it doesn't matter what the scales are, you need to get the theory right. I'm fairly sure from memory that this covered in Machinery's Handbook, but there are many other places that go through this.
