Cole2534
- Sep 10, 2010
- Oklahoma City, OK
A few weeks ago the A/C unit wouldn't get cold so I did some looking and the compressor lead at the contactor was burned in two. The contactor showed no signs of harm so I snipped the burnt end and re-terminated.
Fast forward to tonight and the unit is exhibiting the same issue, however this time the load side of the contactor is badly burned. The clamp screw is welded in place and there are obvious signs of charring on the terminals and surrounding insulation.
What would cause this? Should I ohm out the compressor to see if there's a ground fault issue, or replace it and look for stray voltage?
The contactor unit is a Packard C140A, basically just a single pole relay with 24vdc coil. The failed connection is on the direct coupled leg, as opposed to the switched leg.
Thanks, Cole
Thanks, Cole
