OT: anti-seize compound for aluminium bronze parts at 700c / 1290f temps?
Results 1 to 13 of 13
    May 2017
    FINLAND
    878
    211
    413
    Default OT: anti-seize compound for aluminium bronze parts at 700c / 1290f temps?
    Cylindrical aluminium bronze part inside alu bronze "housing".
    Any ideas?
    Need to be non-smoking(indoor lab use), continuous temps at 700c for hours at a time.
    Jan 2007
    Norfolk, UK
    16,524
    12147
    11568
    Had a quick google, ........ and I'd talk to Loctite.
    Feb 2007
    Aberdeen, UK
    2,707
    956
    888
    There are dry film graphite lubricants that can survive those kinds of temperatures. Idk how suitable they'd be for your particular application...
    May 2003
    Iowa
    9,597
    2797
    3451
    You can make your ownm, but here's what you need
    Colloidal Graphite, Alcohol Base, 3g: Amazon.com: Industrial & Scientific
    If you don't like the alcohol base, you can also get in aqueous suspension.
    JR
  5. Likes digger doug liked this post
    Jan 2012
    Midland, Texas
    1,246
    279
    608
    Look into MicaLube from the BG Service Company. It's used on spark plugs on lean burn industrial engines.
    Oct 2012
    Virginia
    9,286
    4999
    4117
    Quote Originally Posted by MattiJ View Post
    Any ideas?
    Might need a "burn out" period to condition and stabilize it before use for some of the suggested materials.
    Or even consider electroplating one of the two components before assembly.
    May 2017
    FINLAND
    878
    211
    413
    Quote Originally Posted by JRIowa View Post
    JR
    Thanks, that looks like it might work.
    I was thinking of graphite or MoS2. "graphite suspension" could be the keyword here.
    Boron nitride might be also one option
  9. #8
    Feb 2010
    ch
    1,869
    173
    237
    question is: what are you going to do with the powders? you cant just sprinkle them on the bronze, right? there are ceramic pastes i have used that survive well on exhaust collectors.
  10. #9
    Oct 2012
    Virginia
    9,286
    4999
    4117
    "Nickasil' worked in lining Aluminium bores of IC engines. After a fashion.
    Goop for sparking plugs is now Nickel based on many an engine. Copper-bearing, Moly, and others still exist. Moybdenum metal can be plated-on as well as applied as a goop.
    There are probably half a dozen ways to meet your need. All will need testing to confirm they do not contaminate, and that may be costly as well as time-consuming.
    What with the "lab" environment and contamination so unwanted, I'd be tempted to ask if changing at least ONE of the two mating parts to a different material might not be the easiest and longest-lasting approach to avoid seizing.
  11. #10
    May 2003
    Iowa
    9,597
    2797
    3451
    The colloidial graphite is what we use in many nuke applications. The others will stand the heat, but will smoke due to the oil suspension they use.
    JR
  12. #11
    May 2017
    FINLAND
    878
    211
    413
    Quote Originally Posted by Monarchist View Post
    "contaminate" such as messing with Moly or graphite is not too much problem but anything mineral/silicone/xyz-oil based is not wanted if it smokes during heat up.
    Aluminium bronze has been probably best compromise between good thermal conductivity and oxidation resistance.
    This is a temperature calibration "well" or dry block thus the need for thermal conductivity.
    Fluke 917, Fluke 9171, Fluke 9172, & Fluke 9173 Metrology Well Calibrators
    There is some exotic solutions like potassium filled inconel heat pipes or copper block clad with inconel but those are "rather" expensive.
    Now if someone wants to make insert like this cheaply from copper with inconel cladding inside and outside I'm all ears:
    Someone had nice job there drilling the 3mm dia and 220mm deep hole in super nasty aluminium bronze
  13. Likes Monarchist liked this post
  14. #12
    Aug 2005
    Raymond , CA
    64
    39
    Milk of Magnesia (magnesium hydroxide) is used to provide a gap filling, heat conducting, and low strength bond on stainless steel cartridge heaters inserted into heating blocks. I do not know its upper temperature limit. It was the recommended filler for diffusion pumps and plastic injection molding equipment where it might be necessary to remove a burned out heater cartridge without resorting to drilling it out.
    There are a number of patents dealing with this problem. The first one that shows up in a DuckDuckGo search is US 7012226.
    Robert
  15. #13
    Oct 2012
    Virginia
    9,286
    4999
    4117
    Aye. The sort of a task one wants farm-out to a Finn.
    They don't know when to quit, y'see.
