magneticanomaly
Titanium
- Mar 22, 2007
- On Elk Mountain, West Virginia, USA
I am expensively rebuilding the steering box on a little Yanmar tractor, because it is designed to accumulate water, and did.
Normal type manual ball-screw-rack and sector type box. 90 wt gear oil recommended.
Rain (I cover the tractor, but undetermined previous owners didn't) runs down steering column and into steering box. There is no drain plug in box, and no good way to add one as box is set into clutch housing.
My idea is to replace the filler plug with a zerk fitting, and completely fill the box AND column with NLGI 2 Moly EP chassis grease, until it leaks out around the steering shaft (where the water leaks in). If I periodically add grease, that should purge out any water that has leaked in.
Two questions. One, will the grease adequately work its way in, to lube the ball screw? Two, will the grease add a great deal of resistance to the steering in Winter----there is plenty of room for it to squish past the ball-nut-rack as it goes up and down? ( grease can't make Winter steering harder than the ice did!)
Thanks for any suggestions!
