OT - Black engraving inlay
Results 1 to 16 of 16
    Sep 2006
    Middletown, PA
    452
    146
    47
    Default OT - Black engraving inlay
    Made some aluminum Christmas ornaments for a friend with engraved inscriptions.
    I used black Krylon in the engraving for contrast, followed with clear powder coat.
    Problem: the dried paint out-gassed when curing the powder coat, causing bubbles.
    I was able to rework the areas but am looking for a better way next time.
    I recall a rather inert black coloring used in gunsmithing that might be more suitable, although a search of Brownells.com revealed nothing.
    Any insight or recommendations?
    Merry Christmas wishes to all.
    Bob
    Oct 2003
    NYC
    269
    I don't know if this would work in your application, but in traditional clockmaking, engraved dials are made of brass and silvered. The envgraved numerals and details are filled with engravers' wax (by gently heating the work and allowing the wax to "melt in", the excess removed by gentle scraping with a card and then gone over with a fine grit paper). The finished dial is sealed with a clear lacquer. The wax can be purchased from TimeSavers, as Black Dial Wax (part 18948), the url is http://www.timesavers.com/catalogmai...roductID=18948.
    Mike
    Apr 2008
    Northern VA
    318
    I think you are talking about a gun finish called Gunkote... it is a spray on then baked on finish.
    Feb 2004
    Metuchen, NJ, USA
    5,444
    4206
    853
    If baking is an acceptable part of the process, perhaps genuine black japanning from Liberty Paint Co. in Hudson, NY would suit you. - JRR
    Feb 2006
    Indiana
    12,033
    455
    3203
    Gun shops probably sell Birchwood Casey Aluminum Black, a chemical like gun blue.
    Engraving suppliers sell a similar material. I have seen it on eBay, for a rather high price.
    http://cgi.ebay.com/ENGRAVING-MACHIN...1%7C240%3A1318
    Engravers also use colored hard wax to fill narrow/deep lines. It does not work on wide/shallow lines and does not stand up to handling. Ornaments should be OK. The wax came in various colors. It was about the same stuff as crayons, but bigger sticks, so I would just use ordinary crayons or artists' wax pastels. Lumber marking crayons are a bit harder, and would probably be better. I rub it well into the lines, getting it warm in the process. Then I rub off the excess with a hard cloth like an old bed sheet.
    Jewelers also use colored epoxy to simulate glass enamel without heat, which would melt aluminum. That process is more permanent than wax.
    Larry
    May 2003
    Dallas
    77
    Default black engraving
    This web site sells Engravocolor sticks for filling.
    http://www.gravograph.com/usa/Engrav...s_Supplies.php
    Jul 2005
    Midlothian, Virginia
    2,610
    70
    222
    You might try grill/stove paint or exhaust header/engine enamel paint. I would paint, then heat the object to somewhat above the powder coat cure temp, or whatever the paint maker recommends. Then do the powder coat.
    Jan 2006
    Burbank, CA USA
    1,476
    58
    The stuff used by artists doing metal engravings is called Engravers' Ground. It's available from most art supply stores (once you know what to ask for!). I use it to darken the engraving in the brass nameplates that I make up for my musical instruments. I'm not sure what the exact composition is, but it looks about like black coffee. You lightly brush it over the engraving, let it dry for a half hour, then gently scrub the surface with Scotchbrite. The black stuff stays down in 0.005" deep engraving quite well. I believe it's also available in colors other than black.
    Nov 2007
    Fort Worth Texas
    350
    6
    33
    Brownells sells lacquer-stik. Comes in red, white, black and gold.
    http://www.brownells.com/aspx/NS/sto...x?p=7778&st=&s=
    Here's what I did on an adjustable cheekpiece.
    Jul 2003
    Vici Okla. U.S.A.
    1,337
    131
    Bob, the inert stuff that gunsmiths use is a powder called bone black, used to mark the wood when you inlet the metal. Don't know how that would work in your case.
    James
  11. #11
    Jun 2006
    Beaverton, OR
    5,459
    51
    I used generic rustoleum enamel when I was redoing the plates on my Monarch. Dont use spray, use a can. There are more solvents in spray to make it thinner.
    I only went to about 250 to 300 degrees though. I dont know how it will handle powder coat temps.
  12. #12
    Oct 2008
    west jordan, utah usa
    68
    Quote Originally Posted by Bruce Johnson View Post
    Mr. Johnson,
    Do you have a manufacturer name for "Engravers' Ground"? I searched the web sites for many crafts stores as well as a web search and cannot find anything by that name. It may be my lack of computer skill but I'd like to try that stuff if I can find it.
    With my failing eyes and old tools I want to try to darken the markings on my micrometers and calipers so I can see them again. I've tried paint and it just comes off (which is no doubt user error) when I try to get the excess paint off.
  13. #13
    Jan 2006
    Burbank, CA USA
    1,476
    58
    Hello Captf;
    A good online resource for artist's supplies is Dick Blick Art Supplies http://www.dickblick.com/
    I had the product name slightly wrong; it's called Etching Ground. Here's the link for the exact product I have:
    http://www.dickblick.com/zz452/13/#description
    It looks about like coffee (liquid, in the cup). Wipe down the metal part with acetone or lacquer thinner to get it free of oils. Then dab the Etching Ground on with a Q-tip, and let it dry for maybe 15 minutes. Then lightly wipe over it with some white Scotchbrite to take the excess off the surface. It dries hard in a few hours. It may take several applications, but usually one is enough. I use it on engraved brass nameplates that I make up, and it's simpler and better than anything else I've tried.
  14. #14
    Oct 2008
    68
    Mr. Johnson,
    Thank you Sir! I'll give 'er a try.
    Rog
  15. #15
    Nov 2004
    Webster Groves, MO
    6,247
    1500
    2524
    About the toughest black you can put on aluminum is anodize. I have made lots of nameplates with black anodized aluminum coated with Kodak Photo Resist. You expose the resist with UV light, blocking the places where you want it to come off. Wash it off with a xylene solvent and etch, anodize, plate, or whatever in the unprotected areas. The attached pics are of a black anodized piece with the copy etched and a copper plate with the background etched back and gold plated. The copy comes through as almost black, but in real life, it is copper colored. You can strip the KPR off and heat the piece to darken the copper or use one of the blackening solutions.
    Bill
  16. #16
    Nov 2004
    Webster Groves, MO
    6,247
    1500
    2524
    For some reason the pics didn't take.
