So, here is the scenario.
2000 Volkswagen Golf, diesel engine. 108,000KM(about 67,000miles?) goes in for a new water pump and timing belt change at the same time. Car comes out, owner drives about 30km and car stops. Turns out theres a broken valve, it broke at the stem just above the tapered part (I'm no mechanic and don't know the real terms). Dealership says " oh this never happens, it can't be us" and they say over 5000$ to fix it.
Since in the automotive world a lot of things seem to happen by magic, and it is always" the first time this ever happened."
What do you guys see as possible causes for 1 valve to break?
I doubt any pictures were taken of the actual alignment of the belt before the engine was taken apart. So I don't think we can really prove that it was a job done wrong, can we?
I did google and found another instance that is said to be wrong timing and a valve broke, with pictures included and looks just the same.
Would a car make it 30kms if the timing was a little off before something breaks?
So what would you do? is there anything that can be done at all?
Thanks for any Input.
