BACH
- Oct 28, 2005
- Durban South Africa
Hoping someone with ecc. press experience can point me in the right direction.
I have just commissioned a roll forming line forming angle iron out of coiled flat strip (50mm wide x 2mm thick material). The line was bought second hand and was originally used for a larger and heavier section than what I am doing. At the end of the line is an eccentric press, actuated by a limit switch, large solenoid and lever system, which cuts the angle iron to the required lengths. The press has an apparently complex mechanism at the flywheel end of the rotating shaft which engages the shaft to the continuously rotating flywheel to execute one stroke of the tool and then disengages until the next engagement.
The press copes easily with my application, but is pretty worn on the brass/bronze bush in the flywheel, and was a bit noisy and rattling while freewheeling. I decided to run one job through it to establish whether there are any other functional problems, before attempting a repair/maintenance operation.
After about 150 cuts, on and off between roller settings and tweaking the line, I am suddenly having problems with the flywheel engagement system. The press strokes once and the actuating lever then appears to return to the freewheel position, but there is a hell of a clattering from the shaft engaging mechanism as if a dog or pawl hasn't completely disengaged inside. The machine does not keep cycling however. This then goes back to normal after 5 - 10 revolutions of the flywheel.
My question is, can I remove the flywheel and expect to be able to perform a repair in my home machine shop or is this a specialist only function? I have no idea what to expect once I strip the assembly having never seen the inside of this mechanism before.
Any suggestions or advice will be greatly appreciated.
Tony in Darkest South Africa. "What did South Africans use before candles??" Electricity!!
