| General Metalworking, machine tool, and woodworking machinery discussions. Active. |
11-20-2009, 05:07 PM
Titanium
OT. Coarse Or Fine Threads?.. your help please.
I have to make some ''end mill'' type coupling (side screw, whistle notch etc etc) for 1" shaft.
The max ''body'' dia of the coupling is 2" which means only a 1/2" wall.
The material is our EN24 T which I think?? = your 4340 prehard.
Coupling on a machine run by semi skilled + labour,..... AKA they don't break much
1/2" thread, and I'm concerned about wear,..... so do I go 13 tpi or 20 tpi?
Thanking you for your time.
Sami.
11-20-2009, 05:16 PM
Stainless
Limy,
I have a Royal brand R8 endmill holder for 1" Weldon shanks. It is 2.125" in diameter. Royal saw fit to use two 5/8-18 set screws (big fat grub screws to you) to hold the tool. I would guess that the material and duty is similar for your application.
-DU-
11-20-2009, 05:18 PM
I would use the 1/2-20 and put anti-seize grease on the screw.
But I am curious why a Brit would not suggest metric or 1/2-12? I am (obviously) out of touch with current UK fastener practice and preference.
Larry
11-20-2009, 05:29 PM
Titanium
Larry
12 mm ISO is 1.75 pitch (app 14 tpi-ish) and readily available.
Fine rate metrics are hard to find, worse in small quant's and cost the earth.
Both UNC & UNF are common & plentiful, sensibly priced and acceptable to customer.
1/2" 12 is BSW which to all intents and purposes is considered obselete nowdays.
11-20-2009, 06:26 PM
Hot Rolled
I'd go for 1/2"BSF in EN24T. Use coarse threads in soft stuff and cast iron, fine threads in harder stuff. BSW and UNC are too coarse.
If you really must use foreign threads, then go for UNF
11-20-2009, 06:42 PM
Hot Rolled
Quote:
Sami.
Only 1/2" ? That's enough meat to survive a nuclear explosion. You'd have to try damn hard to strip out a 1/2 13 thread. It would take a cheater bar.
11-20-2009, 06:58 PM
Titanium
Quote:
pose that challenge to any operator and within 7 minutes he'll come carrying baCK A TOTALLY stripped, thrashed, and unrecognizable pice of magnetic something with 3 holes in it......
11-21-2009, 12:29 PM
Titanium
Location: North(very) West(very) Ohio...near exit 13 on OH turnpike
Honestly I would search around a little bit and find a nice screw in an existing type of holder, say a Parlec straight shank endmill holder, buy the replacement screw, and tap your device to fit it. The screws they sell for replacement parts are a REALLY nice part in my experience, and probably way under-priced for the quality level.
Bill
11-21-2009, 01:04 PM
Titanium
Quote:
The operators & so called set-up people I work with can *DESTROY* a steel anvil with a RUBBER HAMMER....
I have no idea how they do it...but....sheesh...
11-21-2009, 01:09 PM
I'd use the fine thread. And I'd forgo the antisieze. Antisieze greatly reduces the friction in the threads which increases the chance of stripping. Counterintuitive, but it's true, most noticeable in aluminum. It the monkeys are fond of long wrenches and extensions, let it be hard to tighten, maybe put oil on it.
11-21-2009, 01:11 PM
Hot Rolled
This is the polar opposite of what I've found. Imperial cap screws especially are really hard to find around here.
Gregor
11-21-2009, 01:14 PM
Cast Iron
Hmm, loads of both around here Imperial or metric, course or fine, never had a problem finding any (well, bar an M18 fine thread, that's a fun one)
11-21-2009, 01:33 PM
Hot Rolled
If you need a couple of hundred 1 1/2 UNC setscrews, that's no problem. However, if you go asking for a half a dozen 3/16 UNC socket caps to replace the slideway wipers on the old kearns borer (for example  ) everyone looks at you like you just requested a solution to world conflict. Seriously.
11-21-2009, 01:48 PM
Titanium
Off course the old Kearns borer should have BSW screws in it.
I`ve got plenty BSW and BSF socket caps in 3/8",7/16" and 1/2" diameters.
Comes from running BSA multis.
11-21-2009, 02:02 PM
Hot Rolled
Quote:
That is a distinct possibility. However I doubt it minded too much, especially after running for god knows how long with missing wipers...
11-21-2009, 03:11 PM
Cast Iron
Quote:
www.shop4fasteners.co.uk & www.stagonset.co.uk
Sorted.
11-21-2009, 04:19 PM
I have found that a coarse thread is more rugged and will tolerate more rust, dirt and abuse than a fine thread.
A fine thread is better to resist unscrewing caused by vibration.
11-21-2009, 05:32 PM
Cast Iron
A coarse thread is stronger than a fine thread. A fine thread does not weaken the fastener as much because the minor diameter is greater. Thus fine thread = stronger fastener. Coarse thread = stronger threads. In any case you need at least one diameter of thread length to achieve full strength.
11-21-2009, 05:45 PM
Stainless
Quote:
I always thought it was 0.8xdiamater
That is why a nut is 0.8 x diameter
Please correct me if I am wrong
Peter from Holland
11-22-2009, 01:35 PM
Titanium
Thanks for all your help, I'll be going for 1/2 x 20.
| Thread Tools |
| Display Modes |
Linear Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
Powered by vBulletin® Version 3.8.2 Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.3.2
