matt_isserstedt
- Dec 15, 2003
- suburbs of Ann Arbor, MI, USA
Need some practical advice regarding concrete forms for foundation walls. I'm in the design phase without a lot of good knowledge and haven't found a local mentor...yet. In general, want to pour a 6" thick wall, 48" tall wall, on top of a footing, most of it will be below grade to get below local frostline. 140 perimeter feet total. Top edge will be 8" higher than finished floor, the finished floor is referenced to the finish floor of an adjacent building. General idea is to set 4x8 sheets of plywood on edge to build the 48" height forms.
I found a lot of good info in the Dayton Superior catalog, these guys manufacture a wide variety of breakable cross ties and wedges specifically for such activity, geared towards wood forming. Cold headed and stamped products.
http://www.google.com/url?sa=t&rct=...6CsTQ5bMfMJel1E89kETaRw&bvm=bv.89381419,d.eXY
What I don't fully understand are....
1. In the catalog drawings, there is a 2x4 set flat side horizontal "attached" to the top face of the footing on both sides to act as a brace against blowout on the lower end. However no mention of how the 2x4 would be actually attached to the concrete. Two brainstorm options coming to mind are .22 cal concrete nails, or something like J-bolts pre-embedded on each side of the footing. Both seem to have issues, of either being hundreds of tiny wedges trying to split the green footing, or a lot of extra work to set and then leave behind a lot of J-bolts behind in the footing....and I don't recall ever seeing the latter either.
2. There are tables describing the spacing of vertical reinforcing 2x4s which are laid flat side against the outside of the form. However nothing really describing horizontal reinforcements. What I would like to do is use 2x6s on the outside of the form, laid flat side over top of the 2x4s. The idea being to remove and conserve/reuse the 2x6s as the framing lumber for the building. Silly idea or some merit.
3. understand "form release oil" is to be sprayed before placement. Anything I might have in the shop which I could use? Or if not what is next best? Is it a good idea to use latex paint on the top edge as a form of weather protection as this is built or unnecessary?
4. There is a local craigslist listing for 70+ pieces of 1-1/4" AC ply said to have been stored inside, sold at less per sheet than I could buy 3/4" new. So this has some attraction although I haven't seen it with my own eyes. I realize that must be heavy stuff definitely not a 1 man lift unless built like Lou Ferrigno, which I am not. But the structural aspect and price seems theoretically good.
5. To address "why not hire company with reusable steel forms give them drawings, and write a check". I have had generally bad luck with almost every building trade group I've ever hired and always regretted it later. Some combination of low quality work, make a giant mess without cleaning up, show up when they feel like it and more calls to understand the schedule seem to be met with greater spans between attendance, trying to do what I feel is price gouge me based on location. Bosses promise one thing and the working guys do opposite like they don't even know each other. I have to try to sort out between people in the phone book who has more attention to detail and who has less without much resources or leverage. Granted many of my experiences were from the "building boom" of some years back, so likely the lowest skilled people are doing something else these days. Don't want to turn it into a personal complaint session, but some of you must have been here before, I end up sick to my stomach at the aftermath almost every single time, so I've learned that I just want materials and even if its a lot of work I won't complain. I will spend significant time tweaking dimensions, square and level/grade because I'm also the guy doing the next phase of work and I don't want to have to stop and make new as-built drawings in the middle of the project in order to proceed . However, if some bad experiences have poisoned my brain to the point of being unrealistic regarding above then I need a sense check too
I estimate roughly $1200-1500 to buy the materials (not including concrete) to form the walls above, with the idea of reusing the horizontal stiffening 2x6s for framing lumber later (realize not every single one will survive but hopefully most). I could of course get a quote on the wall project using a company with reusable forms, but I am guessing its going to be significantly more than this compared as closely as possible. 2 guys x 2 days is probably going to eat $500 right there, just considering their basic wage but no profit for their company or consumables, etc.
As always, thanks for any help and advice, good alternatives, etc.
