cls3277
- Jan 10, 2012
- Bohemia, NY
I just had the blade sharpened on my Cincinnati Mechanical Shear. Older machine, but we have never had a problem with it. Anyway, when I sheared some 11 Ga. stainless on it there was a slight tearing / pulling on about .25'' of the cut edge, rather than a clean cut. It is happening a few inches in from the squaring arm, leaving a pronounced kerf on the material (and throwing off my overall dimensions because of the resulting different dimensions). I thought maybe it was the gapping, but I tried increasing it and decreasing it and it didn't improve. Its almost as if the blade is dull at that spot now. When I do cuts in the middle of the shear, they come out fine.
Does anyone have any thoughts on what might be the cause? This is the first time I've had the blade sharpened under my ownership. Is it possible that the blade has been sharpened too many times, taking off the hardened surface and making it struggle with stainless steel?
