My 1997 Dodge one ton is going to need a clutch put in it and I have been doing some shopping on replacement clutch sets. Anyone out there replaced one recently and what did you find that satisfied you. I want the complete kit including the flywheel so that I don't have to have the truck down for more than a day or two. I also DO NOT want a chinese made kit.
The truck is a 2wd 5.9l diesel with the NV4500 5 speed in it and is coming up on 188,000 miles. Everything is stock on the truck although I am working on adapters and studs to swap the truck over to 235/85/16's instead of the 215/85/16's it came with. I also have a Gear Vendors overdrive waiting on the adapter kit to put in the truck as well, gotta see if I can push the highway MPG's over 25.
thanks tim
thanks tim
