seatlanta
- Dec 22, 2006
- Atlanta GA
OK, here's another beginner's problem.
I'm trying to make a set of toolmaker's clamps--you know, the ones in all the project books for beginners.
But I can't thread the 3/8 x 16 tpi holes. I drilled the steel bar to the correct diameter, but the tap goes in about 3/8" and then gets so tight I'm afraid to go farther.
I enlarged the hole by several sizes, and it was better, but I still couldn't get through the steel clamp arm.
I'm using one of those T-handle tap holders with a plug tap. The T-bar begins to flex as it gets tighter in the hole. I'm afraid I'll break the tap if I keep turning it.
I'm using cutting fluid, and I'm periodically backing out the tap to clear it.
Two questions </font>
I'd appreciate any suggestions or tips.
Thanks.
James (seatlanta)
- Should it be this difficult when I thread a 3/8" hole by hand?</font>
- Do I need to buy a taper tap to get it started?</font>
Thanks.
James (seatlanta)
