I've got a couple older newall scales/rods for a dro. They are bent enough that they wont slide freely thru the reader. OK at some points there are small kinks that completely stop the sliding. In some spots when it starts to bind I can twist it and it will slide again, which wont work when every thing is clamped on my tool and cutter grinder.
I've tried to roll on a flat table and tried to bend down the high spots. I've tried to start at one end and work towards the otherside. I'm not having any luck.
I've been thinking of trying to put the rod in a long vee block and pressing at the high spots and rolling.
I'm going to call the local archery shop tomorrow to see they can straighten arrows.
Thanks in advance.
Rosie
Thanks in advance.
Rosie
