Why do I want to convert it? As Matt said;
"Couple reasons: you can run it inside the shop without the CO genie creeping up on you. (It provides some nice heat inside the shop should you require that ) Also, provided the battery can be maintained, an LPG engine fires up immediately...no gumming of carbs or other fuel restriction problems you'd face with a gasoline engine which sits around for long periods in between uses."
It is owned by our Community College and we have the "clean out the carb" routine after every long break.
I need sorces for the conversion parts, or kit. My local forklift dearer wants almost 2 grand to supply the parts and do the conversion. He even quotes $100+ and labor to change a leaky water pump, how he got that notion about a leaky pump, I don't know as he hasn't even seen the machine. Now, know why I want to avoid him and do it myself?
I had several of my own forklifts that were propane and were trouble free.They were IMPCO units, but can I buy them other then from my dealer? I haven't been able to find a website for them yet.
Mahalo,
Doug
