Roscoe Splevins
- Aug 30, 2010
- memphis TN
We are using small thread chasing heads (9/16) to thread full length (4'-6') rods. Heads are in good condition, chasers are from a reputable manufacturer. But our results are pretty poor and not very repeatable.
As new the chaser point of contact is about 0.020" above center line. There is a 10 degree clearance below point of contact and the cutting edge is what the supplier calls a "hook" grind.
Our issues are and inconsistent thread included angle, twisting of the rod, and build up of swarf in the head and inserts.
Others must be having better luck with this type threading process. Wht may we be doing wrong?
