northeastconfederate
Cast Iron
- Jan 25, 2005
- New Egypt, NJ
I work at a 2 on 1 combined cycle power plant; we also have 2 simple cycle (gas only) units next door. I used to work at a steam only power plant. The gas turbines ramp up at startup very fast compared to the steamer and compared to the steamers at my former plant. I am hoping someone can explain to me why the gas turbines are able to ramp up so quickly vs steamers. And please don't say, "Because they are designed that way." I already know that. It's obvious. But surprisingly, this is the answer I get from seemingly otherwise intelligent people.
I know there are pretty tight tolerances between the rotor blades and stationary blades, or buckets in the steamers. The Siemens turbines I worked with before have roughly .030" clearance. So I fully understand the need to warm things up slowly to ensure uniform rates of expansion between the rotor (relatively small mass of metal) and the casing (pretty big mass of metal) and prevent contact, called "rubs", which damage blades. No doubt the gas turbines have similar tolerances? Someone I was discussing this with speculated that the gas turbine casing might have less mass than the steamer, so it maybe expands at a rate closer to that of the rotor. Is this accurate?
Anyone know about this stuff?
