aokun
- Nov 13, 2007
- San Diego, CA
I have a job that has a fairly large chamfer (0.4") in PVC. The length to be chamfered is about 17" and currently I take multiple passes with a 3/8" chamfer mill which matches up pretty well but it does take extra time.
I looked around and the biggest 4FL chamfer mill I can find is 3/4". I need something larger, 1" would be perfect. I do have two different inserted chamfer mills but those only have 1 or 2 effective flutes and don't cut nearly as well as a sharp carbide tool.
Does anyone have a source for such a tool?
Thank you
Alex Okun
Thank you
Alex Okun
