nalambright
Cast Iron
- Mar 5, 2010
- Arlington, TX
It didn't take me long to realize that running a machine shop in 100 degree Fahrenheit heat sucks. I don't get much done and battling sweat and dehydration to focus on projects isn't easy. So I'm ready to insulate and add air conditioning. I plan to go with closed cell spray foam on the outside 1 inch thick with an elastomeric white top coat. I know doing it inside would be cheaper, but the wiring and plumbing on the walls, etc, makes me shy away from that. I'm also considering upgrading from 1 inch to 2 inch thick on the foam. I'll be using a 25000btu a/c to cool the 1600 sq. ft. space. Your thoughts and suggestions are welcome.
