Grits
Stainless
- Dec 14, 2004
- Little Rock, Arkansaw
Hello Everyone
I am parting off .500" slices from a 3.500" piece off round 4140, solid steel bar. I am using a carbide insert that is 0.160" wide. The maximum recommended diameter of my tool is 4.000". The first cut I made was at 100 RPM taking .0025" per revolution using flood coolant. The cutting tool was set slightly above center. The tool holder was perpendicular to the work within 0.0005". The cut was taken two inches from a eight inch Buck four jaw chuck. My lathe is a Nardini 1440E.
I got a good cut but it sure make a nice howl. Nothing bad happened but I had an uneasy feeling. I am somewhat new using a carbide insert for parting off. Am I in the ballpark with my feed and speed? What are your recommendations?
I had a bad experience parting off something smaller using a HSS cutter with an Enco lathe. There was no permanent damage except to my nerves.
Thanks for all your help.
Grits
Grits
