MwTech Inc
Titanium
- Feb 6, 2005
- Fishersville VA
The OEM uses an setup where that has a lever controlling a ball valve.
The lever is a right angle assembly that turns 1/4" sq stock.
Back in the machine there is a ball valve that this lever operates.
Lever in the 3:00 position valve open, 6:00 is off ,1/4 turn operation.
The ball valve is positioned at a 45 Deg angle to the lever shaft and has matching 1/4 " sq stock affixed to it.(in place of the normal handle)
Here is the problem: OEM used rubber hose to connect the two shafts.
Gives a very "soft" feel and now over time the rubber gives and will not operate the valve, worse yet there is a switch that must be made, mounted on the ball valve.
There must be a mechanical joint somewhere that will positively drive the valve through a 1/4 turn at a 45 deg angle.
I can't find one, may just not know the right terms to search.
Andy
Andy
