Bigbore050
- Apr 4, 2016
Looking for someone who has installed the T8 Led tubes in a old fluorescent tube fixture
I'm sitting on about 125 4ft T12 fixtures that either don't work(very dim flicker) or eat through bulbs quicker than I think they should. I assume most of the ballast are old and need replaced. I'm not to electrical savvy and looking for some input.
Instead of replacing all the ballast it seems that a more economical choice would be to direct wire those T8 LED tubes and toss the old ballast in the trash. Replacing the fixtures are not an option at this time.
I'm currently running a discontinued High power factor 277v ballast with F40T12/CW bulbs.
Looking to replace them with these LifeBulb LBU8F225 - 4 ft. LED Tube - 15W - 5 K LED Tube 4 ft. T8 / T12 Replacement - 5000 Kelvin
15 Watt 2200 Lumens 120-277V
As far as I can tell I think they should work and if they do will I be happy with the result. How similar will these be brightness wise compared to the old T12s?
