Clive603
Titanium
- Aug 2, 2008
- Sussex, England
Just pulled the trigger on some house extension work which will require a rather large, by UK standards, door approaching 14 ft wide by 9 ft high to fill the hole at the front of the integral garage. Upwards opening is best for various reasons. Nothing very inspiring around on the UK market. Choice of either affordable crap quality or expensive combination of decent style with apparently optimistic engineering and no attention to operation when the power is off. Being able to drive a P38 Rangie with pipe carrier on the rack into the garage appears to be an unreasonable requirement! As is 30 + year design life.
Hence I need something I can build. A weight counterbalanced horizontal hinge bifold looks fairly straightforward to make but I'm certain there are a number of devilish details which need to be got just so if the thing is to work reliably. The current door is a single leaf top hinged weight counterbalanced 9 ft x 7 ft PortalDoor, over 40 years old and looking good for at least another 20 so I know the basic layout works well and is durable but a PortalDoor won't scale up. Unfortunately the horizontal hinge bifold appears to be unheard of in the UK so I can't go and look at one for inspiration and my design skills are heavily biased to proof of concept and development work, clean sheet of paper efforts tend to be initially er "disappointing" until around Mk3. As these bifold doors seem to be common in America I'm hoping someone can give me some design pointers.
Plan A is to use 2" square or 1" x 2" rectangular steel tube for the door panel frames, monster piano hinges for the pivots and 4" square steel tube for door frame proper. Roll up straps on bobbins carried by a rotating shaft above the door look as good a way as any to do the lifting business. I guess four for the door and two at each end for the counterbalance weights would work. Power drive needed for full opening but will have to arrange an extra set of catches at 7 ft (ish) height for safe manual operation when the power is out. Seems sensible to arrange the power lift to cut in after manually opening the door several inches. Full remotes are just something else to go wrong. If the bottom tube is round it can pivot without digging into the garage floor as the door starts to open. Seems easiest to make the door close against the frame rather than into it. A stainless steel cover plate will give something for the bottom rollers to run against. If the bobbin shaft is a foot or of behind the frame the straps will pull the door back against the frame. Will this be enough to keep things in place as it moves or will a second set of rollers on a floating arm be needed running on the back of the frame?
Chain drive or toothed belt to the center of the bobbin shaft looks sensible with simple micro-switch controls triggered by door movement for up and simple push buttons for down. Will need some way of arranging for the door to relax back down onto the catches or floor when the motor stops. Slack drive and floating tensioner maybe? Electric dog clutch on the motor so door can be used when power is out. Catches are a concern as I'm pants at their design. Obviously need to be triggered out of the way by a short preliminary lift of the door so it can come down past them. Can such things be got off the shelf in the UK and where from? I presume that the door will descend under the excess weight over the counterbalance, controlled by the motor or operator, if the fully open position leaves the panels a little shy of horizontal. How much counterbalance is needed, 80 or 90 % maybe?
Alternative to monster piano hinges would be curved arms pivoting from behind. The concept I follow but not the practical design geometry. A complete new roof going on to the house so I'll have plenty of well seasoned timber out of the old roof and catslide so maybe use that. But my carpentry is strictly nail-gun level. Paslodes are fun!
Suggestions, comments and pointers to design resources gratefully received. Searching Google turns up references to aircraft hanger doors and a few videos of rather rustic devices which look way too dangerous to me.
Thanks for any help.
Clive
Clive
