dsergison
- Oct 23, 2003
- East Peoria, IL, USA
I have a 3500 rpm Tree 325. it has a cat 40 quill style z axis.
I just bought an nice sign engraving program (vcarve) I'd really like to speed up my spindle alot to turn little < 1/4" bits in brass, aluminum, plastic, wood and maybe some steel.
can I run a planetary type -yuasa etc. speeder for hours on end?
is an electric "grinding head" better suited? Or air powered? Or shall i try to mount a small palm router?
also, since it's a quill... if i run a router etc... i will be vibrating and loading my spindle bearings while they are stationary.. unless i make up a z axis way system and use the spindle only to drive it to the height position and it take the vibration and most of the load.
anyone gone down this road?
Thanks, Dan
Thanks, Dan
