Cruisair model FS7C. Split system as below link, which is the condenser compressor assembly, except mine is 1993 vintage and uses R22. Size is 7,000 BTU.
https://yachtaidmarine.com/wp-content/uploads/2014/06/R-Series-Condensing-Unit_web_800-500x500.jpg
Symptom is... when the digital display is set for cool, the fan works fine, the "cool" light will come on after a minute. But the compressor will only run a few seconds and then shut down. Then it "rests" for maybe 20 seconds, comes on for a few seconds again, shuts down....will continue this song and dance forever if I let it. (or would have...keep reading...)
I am assuming all this time it is shutting down due to detecting less than 30 psi of R22 but last week I finally got a Marine AC tech over to the boat who did improve my other unit that needed some R22, but this one he seemed surprised the pressure on discharge side was high if anything... like 150 psi.
He thought the problem was a combination of the motor run capacitor and the relay (in his experience whenever a run capacitor goes, it messes up the relay coil) He had neither with him so I said I'd change those out myself.
This weekend I noticed the next larger unit (that works fine) had the exact same relay and capacitors, so I did a switcheroo....put the relay, start and run capacitors from the good unit in the bad unit.... and vice versa. The end result was nothing....the good unit still runs fine and the bad unit still acts exactly the same.
So the tech was wrong.
Fast forward a few days, talk with another marine AC tech who tells me if the "cool" light stays on the digital display when the compressor is not running then the problem is not electronic. He mentions it could be defective thermal overload in the "peckerhead" at the compressor. So find the overload, check continuity and sure enough it does have .004 ohms between it's two terminals when not on.
So I have the bright idea to straight wire this thermal and see what happens. So I do that, and what happens is the compressor sure enough keeps going far longer than ever before. That is, until smoke starts pouring out.... and the start capacitor begins to melt !
Theories as to why this is happening ? Mine are-
1. Compressor has serious mechanical problem that puts it under undue strain.
2. R22 pressure too high (static pressure on discharge side 150 psi) thus putting too much strain on compressor, such that it never gets beyond the start capacitor stage to the run capacitor stage.
3. ?
Thoughts ?
(I realize one problem with theory no. 2 is that one would think it must have run ok at that pressure when it was first charged or the tech would have lowered the pressure right then and there. But who knows.. )
3. ?
Thoughts ?
