OT Military multi-fuel engine
Page 1 of 2 12 LastLast
Results 1 to 20 of 22
    Sep 2002
    Valley City, ND USA
    1,034
    31
    39
    Default OT Military multi-fuel engine
    The thread on gas in the diesel fuel sparked my memory on these engines. Just wondering if anyone knows what goes on in what is basically a diesel engine(22 to 1 compression, if I remember right) that allows it to burn gasoline as well? I know there is some kind of fuel density compensator, but I have no idea on what it does, or how one ignites gas using just compression without serious pre-ignition problems? Any info would be good.
    Dale Nelson
    Dec 2005
    Auburn, Alabama
    1,438
    114
    121
    I can't answer specific questions on your multi-fuel military diesel, but pre-ignition is not a factor in a diesel because the fuel is not admitted to the heated compressed air until combustion is desired.
    My understanding is that diesel engines could run off of gasoline, if you could easily pump it to the pressure required to direct inject it into a diesel. Diesels running off of petroleum diesel fuel get lubricity from the fuel to lubricate the high pressure pump.
    There might be other reasons diesel engines are not fueled with gasoline, but gasoline having no lubricity for the injection pump has historically been one factor. I remember reading some time ago about a direct injected experimental diesel running on gasoline using an injection pump with ceramic parts. I have never read anything more about running diesels on gasoline, except I've also heard of the military multi-fuel diesel engine and I'm also curious as to how they operate. Maybe you mix some oil in the gasoline?
    Sorry I could not answer you question, but I'm also curious so I thought I'd throw my two cents in.
    Nov 2004
    Birmingham, AL
    13,043
    6147
    2430
    Only things I am aware of as factors on the military multi-fuels is that they run BEST on diesel or jet fuel (pretty much the same things). They CAN run on alcohol, gasoline, or pretty much anything else liquid that will burn, but I do not know what the consequences are. Being military, service due to damage from running on a secondary fuel would be acceptable, given the need to do it... In other words, if running 48hrs on gasoline ruins the fuel pump and injectors, but gets the troops out of harm's way, or gets supplies to a unit in need, that is a perfectly acceptable consequence. Just swap those parts out and keep going. Probably why we don't have multi fuel engines in civillian service.
    Jan 2008
    king george, va
    708
    151
    68
    I googled military multifuel engines and this is all I found. This was in a forum, so investigate before believing it.
    The secret is a special type of injector that sprays instead of fogs, along with a cupped piston that swirls the fuel with a compression ratio of 22 to 1 , and a fuel density compensator in the back of the injector pump that plays a major part in the working.
    Hope that helps
    Ben
    Found it here
    http://www.biodieseldiscussion.com/f...hp?t-5189.html
    Sep 2006
    Dickson, TN
    1,719
    45
    74
    You might check on an ANGIQUE TRACTOR website as there were old tractors made that would run on eitiher gas or kerosene---some would start with gas and by turning or flipping a switch they ran on the kerosene.
    Feb 2005
    Medway, Ohio
    1,354
    147
    111
    We had trucks back in the 40s that would run on coal oil or kerosene after starting them on gas. I am sure some cars were so equiped also. Kenny
    Apr 2004
    Riverdale, Nebraska, USA
    769
    95
    40
    I am currently setting up a 66' model 2 1/2 ton to haul fertilizer. Has the multi-fuel engine (468ci 148hp I think)
    Manual and placards strongly suggest mixing a quart of oil per 10 gallons of gas to lubricate the injection pump. Otherwise, just looks like a typical diesel engine.
    Jan 2005
    Wingdale NY
    142
    Here is a site that will tell you all you ever wanted to know about the multi fuel engines. These guys will run them on dam near anything including 100% pre filtered waste oil!
    Steel Soldiers::Military Vehicles Supersite
    Jul 2005
    Midlothian, Virginia
    2,610
    70
    222
    A buddy has an old Frick sawmill that starts on gas and runs on diesel.
    Mar 2008
    suburban detroit
    648
    158
    Here's a link to an article that is written at a nose-picker level but describes how the engine works nonetheless.
    Steve
    Popular Mechanics - Google Books
  11. #11
    Mar 2008
    suburban detroit
    648
    158
    Steve
  12. #12
    Dec 2000
    Coastal Dogpatch, SC, USA
    50,735
    2453
    5284
    Friend of mine designs, prototypes and tests small engines for military use that can burn any fuel, right here in Beaufort, SC. Website here-
    www.xrdi.com
    You might find the video interesting.
  13. #13
    Nov 2004
    Birmingham, AL
    13,043
    6147
    2430
    Looks like those guys are using the same principle as here..
    FlexDI
    Orbital has used the compressed air/fuel injection setup since the late 80s.
  14. #14
    Dec 2000
    50,735
    2453
    5284
    Quote Originally Posted by sa100 View Post
    Here's a link to an article describes how the engine works nonetheless.
    I like the "stereo in a suitcase" and the "Nag Board"
  15. #15
    Apr 2002
    Syracuse, NY USA
    9,588
    16
    538
    I hear you got some snow Don
  16. #16
    Nov 2003
    Michigan
    121
    19
    42
    Default multi fuel Studebaker
    I had a Studebaker pickup I ran on #2 fuel oil during a time of extreme poverty. It was not happy, but it ran. Lots of blue smoke, knocking on acceleration, and hard starting. If it had not been a hot July and a low compression flathead engine, the attempt would have failed dismally.
    Jim
  17. #17
    Dec 2003
    suburbs of Ann Arbor, MI, USA
    13,039
    423
    1004
    If you ask me its sort of a slug...427cid, 1500lb and produces 140bhp...with a turbo!!!
    Granted its probably a 3" bore and 7" stroke for a fat torque curve but its giving away a lot of efficiency for the ability to burn multi-fuels IMHO.
    There are also early Farmall tractor diesel engines (Super M era, IIRC) which start on gasoline and then switch to diesel operation via operator intervention. Again its prechamber and not much compression.
  18. #18
    Feb 2009
    SF Bay Area, Ca USA
    I drove a 2 1/2 ton truck in Germany in '65-'66. The injector pumps wouldn't last long on straight gasoline. Those were the old pre turbo models. I believe they were made by Continental.
  19. #19
    Sep 2002
    Valley City, ND USA
    1,034
    31
    39
    Thanks for the info and the links. The Pop. Mech. site was basic, but it does explain a little bit more than I knew before. The Steel Soldiers site has more than enough info on anything I could think of, but will take a long time to digest all of it!
    Dale
  20. #20
    Mar 2010
    Davidson NC USA
    1,337
    436
    765
    Smile
    The military multi-fuel trucks include the 2 1/2 ton and 5 ton. The engines were manufactured by Continental and White. The design and license of the engines came from the German firm, MAN. It was called the "MAN Hypercycle Engine". As noted previously, the design relied upon a fuel density compensator, a spray-type injector, a deep cupped piston that helped retard the ignition of the higher octane fuels, and an lube oil spray nozzle that bathed the underside of the piston. To minimize maintenance and improve performance, most operators have bypassed the compensator and only burn diesel fuel. The current generation of military trucks are designed to burn only military diesel fuel, (JP-8). Regards, Clark
