Ray French,
Bearings are the most insane price structure item that exists. A prime example is the ever present #6203 bearing. I buy them for less than a buck each when I ask for the #6203SS grade three item. Asking for the exact same bearing without the shields jumps the price to five bucks each. I take my fingernail and pop off the shields as needed and stock only the SS flavor. The manufacturer tells me that they price the double shielded type so low because that is their prime mover. It takes time and expense to actually turn off the seal inserter and change the packaging.
Almost all the NAPA stores in my area are owned by one guy. He has destroyed NAPA in western Pennsylvania. At one time I had a low number account at a great little NAPA that was owned by a good natured fellow. The place had men behind the counter that jumped through flaming hoops to make sure I was happy. Now all the NAPAs in this part of the country are populated by the same brain dead types that can not even get a set of #CS763P points, after you give them the part number. Most of them ask "what does that fit?" when you give them the NAPA part number. They wonder why my antique account gets such little use. All auto parts customers should pack heat when going to their jobber. If you hate NAPA, you should stroll into Advance Auto Parts. Going there would cause me wear out my aluminum ball bat.
Remember that NAPA is a part of a combine that owns such diversified operations as Motion Industries, S P Richards, and Electronic Materials Group. A lot of times each division actually cuts the throat of one of its siblings. Ain't MBA games fun?
