I am looking for a solution to a highly specialized application. A google search led me to this forum, so I apologize if this post is out of place. Please ignore if so. I need a highly durable, affordable way to direct force from a 1.5"x16" stroke hydraulic cylinder linearly. This application would encounter different surfaces at it's contact point. My intuition is to use two 1.5" stainless steel shafts parallel, connected by a steel plate, utilizing either a linear bearing (expensive), or preferably, some type of poly/UHMW/nylon lined bushing suited for linear and angular forces. I have extremely limited knowledge of machining or material. I apologize if this extremely rookie question is obvious. This forum seems very capable of pointing me in the right direction. Thanks in advance!
