Page 1 of 3 123 LastLast
Results 1 to 20 of 41
    ISIT_RUSTY is offline Plastic
    Nov 2008
    Olive Branch, Illinois
    21
    Default OT - Penetrating Oil
    In a thread in the antique machinery forum, there was a discussion what to use to free up a part. Southbendmodel34 had mentioned a study in Machinist Workshop stating that Automatic transmission fluid and Acetone mixed was the best.
    I just received a newsletter today from Tim Carter mentioning the same study. He had included the results of the test, which I thought interesting.
    A study done by Machinist's Workshop magazine in their April 2007 issue looked at different penetrating oils to see which one did the best job of removing a rusted bolt by measuring the pounds of torque required to loosen the bolt once treated. If the study was scientifically accurate, it turns out a home brew works best!
    Here's the summary of the test results:
    Penetrating oil ..... Average load
    None ...................... 516 pounds
    WD-40 ................... 238 pounds
    PB Blaster .............. 214 pounds
    Liquid Wrench ...... 127 pounds
    Kano Kroil ............. 106 pounds
    ATF-Acetone mix....53 pounds
    hickstick_10 is offline Hot Rolled
    Oct 2009
    BC Canada
    795
    Quote Originally Posted by ISIT_RUSTY View Post
    I notice kerosene isn't on there, which is a shame since its always worked god for me.
    wrenchhead531's Avatar
    wrenchhead531 is offline Aluminum
    Nov 2008
    Fayetteville,AR
    233
    what ATF and what ratio? How do you store acetone in a convenient container where you are not sniffing it all day in the shop and it just evaps out changing your ratio?
    Mike C. is offline Diamond
    Nov 2004
    Birmingham, AL
    9,821
    Two stroke oil is pretty amazing, too.
    Nov 2005
    Maryland
    6,567
    Thumbs up
    That's very interesting.
    I had always heard that Kroil is the best "product" available, and the results appear to confirm that. ATF + acetone is not a "product" that I know of.
    Thanks for the info.
    - Leigh
    Mud's Avatar
    Mud
    Mud is offline Diamond
    May 2002
    South Central PA
    9,633
    Quote Originally Posted by wrenchhead531 View Post
    I mixed the two 50/50 in a plastic squeeze bottle applicator from a beauty supply store. The bottle was translucent and I noticed that the ATF settled to the bottom and the acetone floated to the top pretty quickly. When I shook it up they mixed but you could see that it was not homogenous. No evaporation I could see from the small applicator tip.
    I can't report on it's efficacy. I'm using it on a mounting pin rusted in a pair of hydraulic cylinders. 1 month so far, and it's still stuck. I started with Kroil, so far neither has worked. Looks like it's going to need the torch.
    tdmidget is online now Titanium
    Aug 2005
    Tucson AZ
    2,075
    The so called study did not involve threaded fasteners as I recall. I believe, and correct me if I'm wrong, but it was a press fit. If this witches brew is so good why isn't it in those cans labeled "Kroil" , "PB Blaster", and "WD 40"?
    Nov 2005
    Maryland
    6,567
    Quote Originally Posted by tdmidget View Post
    ...the best job of removing a rusted bolt by measuring the pounds of torque required to loosen the bolt...
    That appears to contradict your statement.
    I've not read the referenced article, so I have no personal knowledge of it.
    - Leigh
    CalG is online now Titanium
    Dec 2008
    Vt USA
    2,232
    how do you know it is not?
    Actually
    According to the MSDS for Kroil:
    1.) Crude oil (Petroleum Base Oil )
    2.) Naptha
    3.) Mineral Spirits (Aliphatic Petroleum Distillate)
    usmachine is offline Stainless
    Jul 2006
    detroit, mi
    1,396
    Kroil rules !
  11. #11
    Nov 2008
    Fayetteville,AR
    233
    Quote Originally Posted by usmachine View Post
    Kroil rules !
    agreed I also use PB
  12. #12
    Aug 2005
    Tucson AZ
    2,075
  13. #13
    RC99's Avatar
    RC99 is online now Titanium
    Mar 2005
    near Rockhampton, Queensland, Australia
    2,891
    I find the oxy works best..
  14. #14
    Nov 2008
    Fayetteville,AR
    233
    blue wrench is always an option
  15. #15
    Don_Hartman's Avatar
    Don_Hartman is offline Cast Iron
    Jun 2008
    Cincinnati,Ohio
    491
    I have had great luck with KROIL on old tractor implement bolts and such. You know the attachments that never get covered up
    Besides I love that Shop-ley smell of KROIL. It'S also alot cheaper than POLO after shave Still stings the same though.
    Don
  16. #16
    PixMan's Avatar
    PixMan is offline Diamond
    Jan 2007
    Central MA USA
    4,136
    I use both Kroil and PB Blaster, but after seeing that report I think I'll just stick with Kroil once the spray can of PB Blaster is gone.
    I lucked out with the 1 gallon (US) can of Kroil I got. I had bought a hand-built tool kart (a nearly 300-pound beast with 8" urethane-covered cast wheels and 3/8" thick welded-on top) at an auction of equipment from the closed Warner Swasey/Norton grinder facility in Worcester MA many years ago. Inside one of the compartments was this nearly-full can of Kroil I was told be a friend that is was especially good and somewhat hard-to-find, so I've used it sparingly for years now.
    Where's a good source to replenish it?
  17. #17
    Jul 2006
    detroit, mi
    1,396
    Default Buy it from Kano Labs
    I buy mine right from the Mfg., Kano Labs in Tennessee. Once you buy a little they will send you deal after deal to get you to buy more
    I bought a couple gallons and a case of spray cans last year and use it liberally as needed. It's not cheap but it sure does work
    As far as the after shave thing goes I only use it for that when I want to keep SWMBO out of the shop
  18. #18
    SteveF is offline Stainless
    Jul 2004
    central NC
    1,723
    Unfortunately, if you read the article, it wasn't scientifically valid and the author pointed that out.
    Steve.
  19. #19
    i_r_machinist is offline Stainless
    Apr 2007
    Dublin Texas
    1,937
    IMPO,
    Kroil is the superior penatrant, but is by far lacking in the ability to help pick up chicks at the tractor pull like a liberal splash of wd40.
    i_r_machinist
  20. #20
    knudsen's Avatar
    knudsen is offline Stainless
    Jul 2009
    Cobblers Knob, IN USA
    1,106
    Kroil is the rats ass. It's probably about the same as the thinned out ATF, but using kerosene. Hard to get acetone/ATF into an aerosol. Nice to know about the ATF and other home remedies in case of a Kroil shortage.
    I didn't see the article, but unless they rusted many, many fasteners in a controlled environment and averaged the results, it probably wasn't very scientific. There must be a huge % of variance considering rust, humidity, bolt tolerances, temperature, application of product, time to penetrate, etc.
    Quote Originally Posted by i_r_machinist View Post
    IMPO,
    i_r_machinist
    Now that would really be tough to prove scientifically. Based on my experience with WD40, they were probably loose to begin with
