DieselPower
Cast Iron
- Mar 28, 2009
- Centerville, TN USA
I service a large custom roofing and trim industry, and am constantly making custom nose pieces for brakes as large as 18ft. I am currently clamping the piece to the table, cutting 2ft, moving it, cleaning chips, re-clamping, setting cutter depths, adjusting, cutting, finding out there is still a chip under it somewhere and pulling my hair out and doing it all over again. It sux... A lot of the work is done with a 2.5" face mill. Do you think it would be possible to set up a roller feed and do the whole cut in one operation? Has it been done before? Sounds scary but I could see it working if it was done right.
Rubber feed rolls
Cast iron rear fence
Chip scrapers and steel front "fence" rolls and down-pressure rolls.
Deeep face cuts (like 80% cutter width) forcing material against rear fence.
Lots-o-lube on sliding surfaces.
And then it will still probably chatter...
What do ya think?
Rubber feed rolls
What do ya think?
