Rob1937 Probably came here because he was excited about a product he had discovered and used with some success, and was eager to share his experience with other like minded people. I take my hat off to a man who has been machining for sixty years, but is still passionate about his interest.
He probably did not come here to be ridiculed by self appointed experts and blog site superstars who have offered very little in the way of useful information, but seem more interested in blowing their own trumpet about how long ago they saw a similar product. Maybe they have nothing better to do than sit on their back sides spouting their fountain of knowledge in chat rooms, and belittling the thoughts and ideas of others.
No one made claims about the insert being new technology. It would be new to anyone who has not seen one before, would it not?
Rob1937 obviously thought it would be nice to share the information with others who may not know such tools exist, only to be labelled a spammer by Mr “3766 posts since 2004”. I hope the previous 3765 posts were worth reading.
So, for any one who is actually interested, these are the benefits of the “old tech” Wonder insert ™
Most inserts are made by pressing carbide powders into a mould. This process produces a relatively blunt edge, which is good for removing lots of material quickly. The down side is high loads and high temperatures which makes fine finishing cuts difficult, especially if you need to remove another 0.05mm to reach your target size. Results can be disastrous with conventional pressed inserts, especially if it’s the last cut on a complex part.
TNGG160404R-S PR1125 inserts are different for the following reasons.
1/ Sharp ground cutting edge for fine finishing cuts.
2/ Also strong enough for cuts up to 3mm depth, and interrupted cutting.
3/ Positive cutting rake for low cutting resistance.
4/ Low cutting force for less chatter on delicate parts.
5/ Less deflection when turning slender shafts or pins.
6/ Suitable for low powered, less rigid machines.
7/ Fine finish is achievable even at very low surface speeds.
8/ Tough carbide grade with special Kyocera Mega Coating for long tool life.
9/ Economical with six cutting edges per insert.
10/ Suitable for most materials, even aluminium and sticky CQ steel.
11/ Fits all makes of holder made for TNMG1604 inserts.
12/ 0.4mm or 0.8mm corner radius.
Use for all carbon and alloy steels, stainless steel, aluminium, copper
brass and even cast iron.
