Kentuckydiesel
- Feb 4, 2011
- Kentucky, USA
I am working on a bit of a different project...a 1961 Lone Star CruiseLiner.
This boat started out life as a 23' cabin cruiser, but back in the 90's, someone removed the roof and converted it to an open bow configuration. It's a great boat...looks a bit like some sort of old military setup. We ran it around all last summer on the Ohio River, and aside from some obvious flex (not good on an aluminum boat), it did great for us.
Anyway, from what I understand, this boat spent most of it's life running around the Chesapeake Bay. While the hull itself has zero problems, the stringers are another story. Over the years, about 60-70% of the rivets have pulled out of the transverse stringers, and many of them are cracked. The stringers also appear to have had some corrosion issues....I'm thinking they were a lower grade of aluminum than the hull.
Here's the question:
I plan to replace all the transverse stringers and add some additional longitudinal strength while I'm in there. While I can track down marine grade aluminum for this, I am not really set up for aluminum.
What I am set up for is stainless. We buy 304L in coils and have material to spare. If I used this, I could do anything I wanted with the hull structure of this boat. My concern is galvanic corrosion between the aluminum and stainless, which would be connected by rivets. I know it is possible for this to occur, but I also know that they are used together in many applications, usually with sealer between the two metals.
If I use sealer at the points of contact before setting the stringers into place, and coat the rivets before inserting them, would I really need to be concerned about galvanic corrosion between the 304L and aluminum in my fresh-water application? (on a side note, this boat is stored on a trailer, so nothing will ever see constant immersion in water)
Phillip
Phillip
