OT- Two post car lift installation
Page 1 of 2 12 LastLast
Results 1 to 20 of 24
    Jan 2004
    NW MN
    68
    5
    Post
    I have a two post car lift to install in my shop, obviously the posts need to be perfectly vertical. The problem is, the entire floor slopes toward the center floor drain.
    The base of the posts are 24" square, the floor drops about .25" over that distance, where the lift will be mounted.
    My three idea's for a fix so far are...
    1. A tapered shim under the base.
    I want the base to be fully supported, so the shim or shims would have to be quite large. I have not come up with a reasonable way to produce such a shim yet.
    2. Build a form and pour some type of harding filler where the base sits.
    I don't know what, if any material would strong enough to do the job at less than .25" thick.
    3. Using a masonry wheel, grind the concrete level under the base.
    This is the method I am leaning toward now, but I don't like the idea of making the floor thinner under the base.
    Any and all thoughts or suggestions on how to accomplish this, are appreciated.
    Mar 2007
    Milford,Ct
    444
    304
    83
    Post
    My neighbor had his garage floors poured the same as yours when they came to install the lifts they used plastic shims that were about 2" in diameter under the base plates at each bolt .The lightest of these lifts is 10000 lb capacity they have been there for 5 years of constant use with no problems .Bill
    Jul 2005
    Midlothian, Virginia
    2,610
    70
    222
    Post
    You might try a concrete resurfacing product:
    http://www.sakrete.com/downloads/pro..._Datasheet.pdf
    Dec 2000
    Bremerton WA USA
    10,637
    40
    4054
    Post
    Install it with a space under the footplates, plumb the columns, trowel a grout the consistancy of mashed potatoes in the space. "Por-Rok" is a material I've seen used in this connection.
  5. Likes TFPace, JoeE. liked this post
    Jan 2006
    Houston, TX
    6,087
    565
    1028
    Post
    I'm curious..
    What do the instalation instructions tell you to use for bolts to to hold the floor plates?
    What does it say about the concrete slab?
    Jul 2005
    2,610
    70
    222
    Post
    Perhaps hydraulic cement?
    http://www.wagnercompanies.com/Rockite.aspx
    8,000 PSI compression strength.
    Sep 2007
    Stafford, Ct.
    63
    Post
    Do me a favor. If you use shims, make sure you anchor them in some way, epoxy or cement. If you draw a sketch of the mast, shim, and floor you will see the shim as a slight triangle. Now, going back to your high school physics, vector the forces. If the shim is too steep, the lateral forces will overcome the friction holding the shim in place.
    Can you say shrapnel?
  9. #8
    Aug 2005
    Hampton, NE
    11
    Post
    I've installed the Rotary 12,000 # lift in my shop. Rotary supplied U shaped plastic shims to use under the 3/4" anchor studs torqued to 150 ft.lbs. I have not seen any problems even when loaded to capacity. Max
  10. #9
    Dec 2003
    suburbs of Ann Arbor, MI, USA
    13,039
    423
    1004
    Post
    Along the lines of retaining shims, when you realize the final height, you can tack weld the compressed stack or simply measure and add the thicknesses and make a custom 1-piece shim with your shop equipment [img]smile.gif[/img]
  11. #10
    Oct 2002
    Poetry Texas USA
    1,628
    170
    150
    Post
    If everything is square and plumb, what difference does 1/4" make in that distance. I have 6 lifts of 2 different brands in my shop and they have been trouble free for 25yrs. Each side is adjustable if needed. I bet where you pick up the vehicle is further off than that.
    Butch
  12. Likes Rob F. liked this post
  13. #11
    Jul 2007
    southern california
    221
    Post
    Another idea would be to use a cerro-bismuth based metal. Melting temp varies from 150 to to about 300f. I saw a big planer mill (60x15 feet) leveled with it.
    re
  14. #12
    Mar 2006
    Auburn CA
    300
    Post
    Forest has the answer (of course). Almost nothing is mounted to a concrete slab without some form of leveling grout.
    However, you raised another concern. If you are concerned about the slab being too thin after grinding off a 1/4 inch, then it is already too thin. I have never installed such a lift but I would guess that the proper installation calls for several inches of embedment of the anchor bolts and an even thicker, steel reinforced slab in the area of the anchor bolts.
  15. #13
    Sep 2006
    Nevada
    296
    14
    77
    Post
    I have installed heavy machinery and the way I would anchor and plumb the lift would be to epoxy all thread anchors into the floor, then use a leveling nut under the plate and one on top of the plate to anchor the plate with the post vertical. I would then grout the plate with a hydraulic cement which does not shrink. By putting leveling nuts under the plate, you are allowing enough room to get the hydraulic cement to fill the complete bottom side of the plate and provide full support.
  16. #14
    Jan 2006
    Brookfield, Wisconsin
    3,855
    193
    326
    Post
    I got a question
    What if he was to use the method that modern traffic light collums use, i.e. the column's base itself doesn't rest on the ground but rather there are nuts threaded onto the bolts and these nuts sit between the column base and the ground.
    He could allways then fill the inbetween space if needed.
    If you see in this picture, you'll notice the gap I am referring to,(not a great picture but couldn't find any better).
    traffic column
  17. #15
    Mar 2005
    Hamersville,OH
    342
    Post
    If you use leveling bolts under the pads then you are going to loose that much clearance for the lift arms to swing under low cars.I can speak from expierience, these arms need to damm near touch the floor when swinging ! I installed mine with just small steel shims under the corners that needed them.
    I like the idea of grinding the floor. Get a transit and start at the lowest point,grind everything off that is higher than that. Good luck....Randy
  18. #16
    Mar 2004
    Lancashire UK
    36
    Post
    I would be more bothered about the vehicle rolling about before it is jacked than the posts being plumb. Obviously you want brakes off / out of gear before it is lifted. Not sure that 1.5inches in 10 ft would allow the vehicle to roll, may be worth experimenting before the lift is positioned?
    regards, Steve.
  19. #17
    Nov 2012
    Brisbane/Australia
    6
    Quote Originally Posted by Steve Riley View Post
    regards, Steve.
    Yes I agree with Steve post, he really expose his idea very well...
  20. #18
    Jul 2005
    Eastern PA
    881
    109
    571
    My floor is pitched towards the doors. My two post came with a bag of U shaped metal shims just for that possibility. I plumbed the posts using the shims and have not had any kind of problems. No need to over think this..............Bob
  21. Likes t.jones liked this post
  22. #19
    Jan 2006
    Portland, OR
    132
    39
    6
    Quote Originally Posted by maxk View Post
    This is the best answer. I helped install a two post that is in a shop space I share and this is exactly what is done. I would ask the manufacturer for the correct shims and get it reasonably level and call it good.
  23. #20
    Apr 2008
    Raleigh, NC
    177
    30
    43
    I have never seen the requirement to release brakes and have a car out of gear prior to lifting the vehicle unless the work had to do with the drivetrain and having to rotate things like drive shafts or half shafts. Same for my son that was a dealership mechanic. 99% of the time the cars were in park if it was an automatic.
