I had a garage that had a driveway that sloped into the garage as well. I used to get some major flooding in my garage as a result. I took some 2 x 4 pressure treat, beveled it on both sides leaving a 1/2" top on the 3.5 side. Creating in effect a berm. Hit it with Thompsons water seal for two coats as well to prevent the swelling, UV damage and such that may occur, then screwed it into the driveway about 1 inch in front of the door - driveway side- with many 1/4" concrete screws (countersunk, these were not pan heads, they were hex head and substantial) with lead "liners" like putting them in a concrete wall.
Then I sealed the bottoms to the driveway with some caulking type driveway sealer, making quite a nice bead if I say so (like doing a tub bead, but with much more stuff).I also very lightly sealed the seams between boards with this as well while putting it together.
Each year I hit it with a coat of Thompsons. They never came loose and I only had to redo the beads twice due to normal driveway expansion and contraction - and only in a couple of spots.
This served me quite well for fifteen years, I passed by the old house and the rig is still there.
I had no room for a small drain swath of slit under the door due to the grade to the door and around the drive and the fact that the entire grade of the property to the garage was right to the building for the 20 feet length I had to deal with (a 40 foot garage and barn total, done in 1905 and adapted to a garage after being a horse barn). This set up was was a necessity at the time. Howeever, I then created a drainage area in front of the entire structure away from the asphalt by rototilling the yard about 14 inches deep by three feet wide, loosing about 80 years of compacted dirt - horseshoes and other assorted neat things. I read about "Prescription turf" and drainage turf as done at the old Mile High stadium and proceeded to put down about 6 inch pea gravel, topped it with large grit sand after putting down some open screen to create a bit of a barrier, then put down about 1/2 inch top soil with another barrier (I had the help of a landscaper friend to create this work of art) then some turf from a local turf farm. This created a real great drainage area that never held standing water and it was there i drained the standing water from my driveway and barrier.
Though this sounds complicated, the garage situation I was in - I wanted the solution to last pretty much a lifetime rather that mess with it on a yearly basis. The drainage turf idea worked so well that I did it on other areas of the house where the slope (with no way to change it) went to the house. It took a full summer, this after my first winter of fighting flooding in the garage and a frozen in car and a flooded cellar, It took about three weeks the first part around the garage, I actually tried to flood the drain turf to test it, then about four weeks around the house. The result was a home that was quite resistant to flooding and more or less "self drained" for the fifteen years I was there after I did the work, and the buyers are still happy with it. The reason I mentioned it to the buyers (along with my neighbor swearing by what I had done because he used to help the person before me bail the cellar and also helped me with the solution) was because the realtor and home inspector were leary of the slope and potential problems.
Thge drain areas also never seemed to freeze up, I think due to the ability to hold snow on top and the depth of loosened dirt. However, the same area was not soupy or spongy due to the pea gravel over the loosed and moderately compacted dirt base.
The only drawback was having to water the drain out areas during summer times where we did not get rain on a weekly basis and fertilizing the areas with starter fertilizer on a yearly basis. I needed the grass to stay alive to keep the top soil sturdy
Sounds crazy and a bit obsessive compulsive, but after bailing a cellar six times in a winter and the inability to use a garage the first year I was there, doing it right paid off for years and years. It was also a bit of the engineer in me that made me this crazy about fixing it right, and I consider this my greatest "home engineering project" to this point.
