OT/ What is substutition for Lime-Away?
Results 1 to 12 of 12
    Aug 2005
    Hernando, FL
    6,523
    1511
    2161
    Question OT/ What is substutition for Lime-Away?
    I remember reading a long time ago about a common chemical which does the same job as Lime-Away and for less money..
    Anyone know what that is?
    Apr 2002
    Syracuse, NY USA
    9,588
    16
    538
    phosphoric acid is probably the ingrediant in Lime away, that is what is smells like. Vinegar would probably work as well
    Sep 2004
    Oakville, ONT, Canada
    337
    Lime away, aka CLR is glycolic acid solution, I guess it is used because it is a mild organic acid (kinda like citric but with an alpha hydroxy group) yet it is strong enough to dissolve basic deposits in a reasonable time.
    A cheap substitute would be phosphoric acid or even cheaper muriatic (HCl) that has been diluted, if you have the neccesary protective equipment. Phosphoric doesnt fume but it can be hard to find.
    Jan 2007
    New Hampshire USA
    700
    25
    Muriatic acid.. serious etching and dissolution.
    Vinegar....for very gentle action.
    SM
    Aug 2005
    Hernando, FL
    6,523
    1511
    2161
    Thanks... We are using the vinegar now.. Works good.
    Jun 2001
    St Louis
    16,846
    1428
    2583
    Phosphoric is easily available at Lowes etc if you look for 'concrete etch". Much of it is phosphoric.
    Great rust remover, and unlike muriatic, it will not spread rust all through your shop
    Aug 2005
    Hernando, FL
    6,523
    1511
    2161
    Is that the same that goes by the name Ospho? spelling?
    Feb 2006
    Northern LP of Michigan
    679
    Quote Originally Posted by JST View Post
    I've been using peletized acid that I believe is phosphoric to clean the screens in my well. Does anyone know if concrete etch would be a locally available substitute.
    Clutch
    Jun 2001
    St Louis
    16,846
    1428
    2583
    Quote Originally Posted by rj newbould View Post
    That is a specialty version which contains, but may have other stuff besides, phosphoric. I think it is specifically a paint pre-treat, with extras.
    Nov 2005
    N E Florida
    1,995
    169
    If you have a Dollar Tree near by they sell a product called "The Works Tub and Shower Cleaner" . The stuff works great. I use it on my boat to clean that scum and stains that get on fiberglass. It costs $1. a bottle. The hull cleaner at the boat store cost $10. The cheap stuff works just as good. You can smell some kind of acid in it.
  11. #11
    Dec 2000
    Bremerton WA USA
    10,637
    40
    4054
    Dpmn't ever use muratic acid indoors. The fumes travel everywhere causing rust, lifting chrome, and inflicting general mischief in the most unespected places. The fumes even migrate through plastic jugs.
    Use phosphoiric acid for general etching and lime removal. If you have more time use acetic acid like white vinegar.
  12. #12
    Oct 2006
    Kintyre ND
    118
    17
    Default Iron Out instead of Lime Away
    IMO hands down a product called "Iron Out" is the alternative to lime away. The odor is strong but the out come is good.
