upthebikes
Cast Iron
- Aug 23, 2007
- Great Lakes USA
let's just suppose that i want to mount a 2j collet chuck to flat plate, such as a right angle plate. i already have the 2j collets that i'll need- 1", 1 1/8", and 1 1/4"
i am envisioning a tube coping/mitering setup as follows: rotary table mounted to horizontal mill table. right angle plate with hole machined to allow largest diameter tube to pass through it. 2j collet chuck mounted to right angle plate, centered around hole on plate, to hold collets. tubing in collets. dial appropriate angles on rotary table, and cut away.
almost every 2j collet chuck i see is either a hardinge, or sjorgen (now ats workholding?), and they mount to a d1-6 lathe spindle.
what are my options here? i'm a real greenhorn at this, and having trouble picturing exactly how the mounting scenario would work.
would it be easier to find somebody to make a 2j collet block (which i've never seen?)
i searched for similar questions, but couldn't find anything.
i appreciate any help, and thanks.
